Old 06-05-2009, 04:44 PM   #1 (permalink)
Default DOS screen problem
Dear all,
My problem is with regard to the DOS screen in windowsXP. Whenever I run a dos game or program from dos screen (cmd) under WndowsXP, it automatically gets minimized but not closed. It can be restored to the full screen by clicking on the task bar but again it gets minimized automatically after some time. Is there any solution to resolve the issue?
I am using windowsXP service pack2 in P3 1GHZ system with 512MB RAM and 80 GB Hard disk.
Please help.
Thanking you,
aditya
aditya2053 is offline
Old 06-05-2009, 06:03 PM   #2 (permalink)
Call me D_J!
Disc_Junkie's Avatar
Default Re: DOS screen problem
See if it helps!!
RightClick on the exe file in Windows, select Properties, select Screen and under Usage select Full Screen!!
ASUS K42JA-VX032D RAWKS !!!!!!:grin:
Disc_Junkie is offline
Old 07-05-2009, 08:41 AM   #3 (permalink)
Thanks for your help. But this has not helped my problem. Even after setting the properties to full screen, the DOS screen gets again minimized automatically.
By the way, I am using AGP card with samsung monitor. Has this problem anything to do with AGP card? Please kindly help.
With best regards & thanks,
aditya2053
