Old 05-05-2009, 02:34 PM   #1 (permalink)
Default help!!!!!!!!!!
i have an intel dg31gl motherboard with a e22oo dual core .which graphic card should i upgrade for good gaming ecperience
ishan.khandelwal is offline
Old 05-05-2009, 02:41 PM   #2 (permalink)
Default Re: help!!!!!!!!!!
how much can u spend?
awww is offline
Old 05-05-2009, 03:09 PM   #3 (permalink)
Democracy is a myth
rhitwick's Avatar
Thumbs up Re: help!!!!!!!!!!
If "Intel DG31GL" is ur mobo. then, as per spec in Intel's site.
It doesn't have any dedicated GFX slot.
There are Grafix card for PCI slot but u need to search well and they might be costly but won't be vale for money at all.
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is online now
Old 05-05-2009, 10:52 PM   #4 (permalink)
King of my own Castle
freshseasons's Avatar
I suggest you get yourself a decent motherboard with a PCIe 16X (GFX) Slot.
Buying a simple PCi slot graphic card is going to be costly and the performance would be half of what you had pay for a regular graphic card.
freshseasons is offline
Old 06-05-2009, 10:01 AM   #5 (permalink)
prateek007391's Avatar
Wat is better PCI Express or AGP
wat is the difference in performance, price and capabilities???
prateek007391 is offline
Old 06-05-2009, 11:08 AM   #6 (permalink)
Bond, Desi Bond!
desiibond's Avatar
@prateek, AGP is outdated and end-of-life Graphics Port. It is lot lot slower when compared to newer PCI-Express graphics port/slot.
Only AGP cards you can find now are older cards that are still in stock with dealers. Noone is now manufacturing cards for AGP.
http://en.wikipedia.org/wiki/Accelerated_Graphics_Port
AGP 8x has maximum data rate of 2133 MB/s (2 GB/s)
PCI Express 2.0 has 4 GB/s in each direction (being full duplex, it would be 8GB/s)
desiibond is offline
