Old 17-06-2005, 01:14 PM   #1 (permalink)
Default MSN MESSENGER HATES MY ACCOUNT!!
Suddenly i am not able to to access my hotmail account through MSN Messenger 7.....though it logs on to my sister's account without fail!!...what the hell is going on??.....iam using avast! pro and Zonealarm.....but i dont think they are creating a problem beacuse i have been using them for a long time and this wierd thing started to happen just 2 days ago!!
sahil_blues is offline
Old 17-06-2005, 01:22 PM   #2 (permalink)
expertno.1's Avatar
whan??
1)do u typed ur usename or password correctly
2)first use browser to check ur msn account
3)from how much time u r not using your account
expertno.1 is offline
Old 17-06-2005, 01:24 PM   #3 (permalink)
The Hardware Labs
mohit's Avatar
maybe somebody cracked ur account and changed the password ... use the forgot password link and change ur pass there by filling all the necessary details and then see if u r able to log in.
mohit is offline
Old 17-06-2005, 02:23 PM   #4 (permalink)
no guys its not that.....i used Windows Messenger and it worked fine...its just with MSN Messenger .....i check my mail daily.....its not due to wrong Username or Password....
Old 17-06-2005, 04:54 PM   #5 (permalink)
expertno.1's Avatar
then unistall the new messenger and install the old version walla and then try
Old 17-06-2005, 06:08 PM   #6 (permalink)
What? Where? How?
escape7's Avatar
Use the old one or create a new ID .................................................. .................................................. ...........................................Bad Suggestion i guess...
98% of the people using internet have started or forwarded "chain mails". If you are one of the 98%, Die a horrible death.
escape7 is offline
Old 17-06-2005, 07:46 PM   #7 (permalink)
i tried that....but as soon as i sign in it says a newer version is available....(without giving any option of continuing with the older version)....then i downloaded the newer version again (this time through MSN Messenger itself).....but the same thing is happening again....
IT IS a bad suggestion...!!!
Old 17-06-2005, 07:49 PM   #8 (permalink)
Just Do It
Charley's Avatar
I've tried that many times but never works........ Its only a gimmick from them...
Charley is offline
