Old 17-06-2005, 12:16 PM   #1 (permalink)
Default Port Scanning my COmputer ?
I need a good online tool to port scan my computer for vunerabilities. which should i use ???
Abhinav
cyberia.in is offline
Old 17-06-2005, 12:39 PM   #2 (permalink)
There are number of good online scans are available namely :
1. http://www.hackerwatch.org/probe/
2. http://scan.sygatetech.com/probe.html
3. http://secwatch.org/probe.php
godblessedson is offline
Old 17-06-2005, 12:44 PM   #3 (permalink)
Try NMap -
http://www.insecure.org/nmap/
Hardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM
Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE
Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e
ujjwal is offline
Old 17-06-2005, 05:55 PM   #4 (permalink)
Nmap wont allow you to scan on own IP unless you are scanning from the outside that is the internet.
Which also requires a fair amount of understanding of ports & various options present in nmap.
For a online port scan you can as may try Steve Gibsons Shield's UP
www.Oobertech.net
digen is offline
Old 17-06-2005, 06:11 PM   #5 (permalink)
Nmap will show error like "Local Loopback not supported or something"
Try scanning ur computer with Retina from e-Eye.
Most comprehensive scanner with a lotsa old and new bugs built-in
( No support for Win98 )
Hibernating ....
banned2wise is offline
Old 17-06-2005, 07:57 PM   #6 (permalink)
Just Do It
Charley's Avatar
This is nice....
Charley is offline
Old 17-06-2005, 09:48 PM   #7 (permalink)
Hmm ... I was able to use nmap to scan my local PC quite simply -
$ nmap 127.0.0.1
Starting nmap 3.81 ( http://www.insecure.org/nmap/ ) at 2005-06-14 16:24 IST
Interesting ports on archlinux.sify (127.0.0.1):
(The 1662 ports scanned but not shown below are in state: closed)
PORT STATE SERVICE
6000/tcp open X11
Nmap finished: 1 IP address (1 host up) scanned in 5.901 seconds
But I guess I am missing something here, as I do not know much about networking.
ujjwal is offline
Old 18-06-2005, 07:32 AM   #8 (permalink)
l33t n00b!
Nimda's Avatar
Retina would probably be an overkill for this. There are online vulnerability scanners out there on the web like the one digen suggested. Here are a few others.
Nimda is offline
