Re: display the size of folder
The behavior is called "Tool Tips".
By default it should be enabled in ur OS.
If u r using XP, I can guide u to enable it.
Go to Tools-->Folder Options-->View tab.
Here u will find a "checkbox" having value "Display file size information in folder tips".
Tick it and press OK button.
Now u would get Size and Folder content info when hovering mouse over any folder.
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
