Old 16-06-2005, 10:21 PM   #1 (permalink)
Default Prolem Surfing the Net
Hi People,
I use proxy server to surf the net but the problem is that I can't download anything beyond 1- 1.5 MB.
When try to download such files then suddenly the download stops in between and it says whole file downloaded.
Also I can't watch streaming audio and video.
Some error like "DNS error" appears.
Please tell me whats the solution.
freezer is offline
Old 16-06-2005, 10:35 PM   #2 (permalink)
expertno.1's Avatar
what downlaod manager u r using
ur config ?
lol !
config !!!!!
expertno.1 is offline
Old 16-06-2005, 11:53 PM   #3 (permalink)
I don't use any download managers.
freezer is offline
Old 17-06-2005, 12:34 AM   #4 (permalink)
String Phreak
mediator's Avatar
Well dont try proxy then! Check direct internet connection first,
coz proxy server is also a machine which manages thousands of connection. So to prevent system overload the admin may have limit its transfer capacity!
mediator is offline
Old 17-06-2005, 12:36 AM   #5 (permalink)
String Phreak
mediator's Avatar
Ok for DNS I suggest flushing DNS,repairing DNS !
coz DNS might be corrupt!
mediator is offline
Old 17-06-2005, 12:46 AM   #6 (permalink)
Try this !!! wat service r using ???
Cheers !!!
\"Live Life as it comes & Live it KINGSIZE\"
\"Learn From Yesterday,Live For Today & Hope For Tomorrow\".
Bye 4 Now - N_!_r_a_L
King_Niral is offline
Old 17-06-2005, 09:53 AM   #7 (permalink)
How to do that I don't have any knowledge about it.
freezer is offline
Old 17-06-2005, 09:56 AM   #8 (permalink)
I use Airtel GPRS
freezer is offline
Old 17-06-2005, 10:58 AM   #9 (permalink)
QA Juggler
saROMan's Avatar
well it can be the problem of proxy ur using..try changing the proxy and see if it works.....
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 17-06-2005, 12:16 PM   #10 (permalink)
If i don't use proxy servers then no data transfer takes place
freezer is offline
Old 17-06-2005, 12:29 PM   #11 (permalink)
expertno.1's Avatar
Originally Posted by freezer
I use Airtel GPRS
hey i aslo use Airtel gprs
and dont use proxy
u should enable the feature of obtaind dns automatically
no proxy
i dont use proxy
try to download without proxy
Old 17-06-2005, 01:32 PM   #12 (permalink)
Distinguished Member
anandk's Avatar
how to do it ? would just like to know ! 8)
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 17-06-2005, 10:18 PM   #13 (permalink)
anomit's Avatar
Use this command:
C:\ipconfig /flushdns
for flushing DNS resolver cache
Don\'t SYN me, I'll SYN you. :p
anomit is offline
Old 17-06-2005, 11:55 PM   #14 (permalink)
I tried to flush DNS but some error comes
"Unable to locate server. This server does not have a DNS entry. Please check the server name in URL again and try again.
freezer is offline
Old 18-06-2005, 11:09 AM   #15 (permalink)
Rebooting
Choto Cheeta's Avatar
man... freezer.... u r already in an proxy... AirTel GPRS dont give Static IP... then why do u want to use a proxy... as AirTel GPRS is not fast as the CDMA data connection... & proxy will going to slowdown ur system a lot....
better go without any proxy...
Choto Cheeta is offline
Old 18-06-2005, 12:26 PM   #16 (permalink)
Hey but as i already said that no data transfer takes place If I don't use proxy.
freezer is offline
Old 18-06-2005, 12:31 PM   #17 (permalink)
Just Do It
Charley's Avatar
Thats really weird .. My ISP doesnt require a proxy. Have u tried hooking ur customer care and caring to ask them abt the prob ??
Charley is offline
Old 18-06-2005, 12:38 PM   #18 (permalink)
I asked customer care but they don't kow anything about how to configure it. Also I reached one of there showrooms. Even there they couldn't help me
freezer is offline
Old 18-06-2005, 01:51 PM   #19 (permalink)
Just Do It
Charley's Avatar
If the customer care doesnt know then who wud know
BTW why dont they know since ur using a proxy that wud have been given or be used by them also.
These customer care blocks are only just for the heck of it...
Charley is offline
Old 18-06-2005, 01:53 PM   #20 (permalink)
Rebooting
Freezer Guide for u to cofig ur system...
1st off all the phone setings... now its depends on ur hand set... well try to delet its connection & make anpther or just send a sms request to the airtel service no. to send u an ph config based on ur model....
2nd thing for ur computer.... delet all connection releting AirTel GPRS... deactived the proxy, if possible thenuninstall.... now i hope u r in XP.. though all the windows r almost same to config....
Go to Network Connections & creat a new connection.... next to connect to the internet, then ste up connection manualy, connect useing a dial up modem, ISP name can b AirTel GPRS, phone number to dial is *99***1# (confirm from customer care..)... & user name is ur ph number (in this format 919xxxxxxx) & the leave the password blank...
now connect without ur proxy & get back....
& i realy dont understand why a ISP would requeard a user Proxy....
