Old 16-06-2005, 08:45 PM   #1 (permalink)
bharat_r's Avatar
Default My Hard-disc's life
I have 2 hard-disks.
I installed a prog called HDDLife.
& according to it's tests these were the results:
The life of one of my HDD is 20% .What does it indicate & how do I fix it.
bharat_r is offline
Old 16-06-2005, 09:49 PM   #2 (permalink)
expertno.1's Avatar
so how old is your second hard disk ?
if ite not old or old then the problem of this message is due to bad sectors and less speed detection of hard disk
use defragment the hard disk
expertno.1 is offline
Old 16-06-2005, 10:13 PM   #3 (permalink)
What? Where? How?
escape7's Avatar
how do i do this test?
98% of the people using internet have started or forwarded "chain mails". If you are one of the 98%, Die a horrible death.
escape7 is offline
Old 16-06-2005, 10:16 PM   #4 (permalink)
l33t n00b!
Nimda's Avatar
@bharat:
The health and life condition of the hard drive.
It shows the percentage of the remaining health and life of your hard drive. A perfect disk (though there are no such disks as there are no perfect people would have 100%. As the disk works and becomes “worn out”, the level decreases. As in other visual elements, the green color means that everything is all right, yellow means an urgent state, and red means that the state is critical and the disk must be immediately replaced.
The performance level of the hard drive.
It estimates the overall performance of the hard drive based on some of its technical parameters. Mind that this parameter concerns the hard drive only and the total performance rate depends on your computer. Use this parameter rather as an informational means.
Source : Taken from the HDDLife FAQ. (Help menu).
Nimda is offline
Old 16-06-2005, 11:02 PM   #5 (permalink)
expertno.1's Avatar
so how does this HDD works ..on which pronciple it works ?
Old 16-06-2005, 11:15 PM   #6 (permalink)
bharat_r's Avatar
Nimida thanks,I could have read it myself from the help .I wanted a way to fix it.
Thanks anyway.
The segate is 5 years old,the samsung one is 2 years old.
I'll try defragmenting...
bharat_r is offline
Old 16-06-2005, 11:18 PM   #7 (permalink)
bharat_r's Avatar
Windows XP does not have a detailed Scan Disk as in Win 98(does it?)
Is there any safe 3rd party tools for this?
bharat_r is offline
Old 16-06-2005, 11:38 PM   #8 (permalink)
godsownman's Avatar
bharat_r
Where did you get the software from.
I tried google but got only shareware.
I'm still searching
From the body of one guilty deed a thousand ghostly fears and haunting thoughts proceed !
Visit (http://www.meebo.com)
godsownman is offline
Old 16-06-2005, 11:43 PM   #9 (permalink)
godsownman's Avatar
Is it from www.hddlife.com and is it a 3mb software.
Old 17-06-2005, 12:13 AM   #10 (permalink)
The Hardware Labs
mohit's Avatar
@godsownman
ya its the same software ... just downloaded it and it shows the perfomance and health of my 1 year old seagate sata to be be 63%
mohit is offline
Old 17-06-2005, 01:00 AM   #11 (permalink)
bharat_r's Avatar
mohit,that must be becose ur HDD must have been cluttered & do u have frequent power cuts & u r without UPS?
yes it's a shareware...use it within 30 days.
bharat_r is offline
Old 17-06-2005, 01:06 AM   #12 (permalink)
The Hardware Labs
mohit's Avatar
@bharat_r
no not all ... i defragment very regularly .. have all ntfs partitions with no crap at all . and i have a wipro ups and also an antec power supply. god knows whats wrong ? even the temp of my hdd is shown under control i.e 34C which is not harmful... i am just wondering whats the problem ? and beleive me i take extra care of all my components by defrags and dust clean up's etc... god knows whts wrong.
mohit is offline
Old 17-06-2005, 09:29 AM   #13 (permalink)
bharat_r's Avatar
I defragmented the 2nd HDD but it still shows 20% health.
bharat_r is offline
Old 17-06-2005, 09:36 AM   #14 (permalink)
l33t n00b!
Nimda's Avatar
Well, looks like you didn't read the help carefully after all . When it says "worn out", it is most probably referring to physical damage which can't be fixed with any software. I recommend doing a scan for bad sectors using chkdsk. If bad sectors are found, then go to this page on Seagate's site.
Nimda is offline
Old 17-06-2005, 10:20 AM   #15 (permalink)
godsownman's Avatar
Thanks Mohit I downloaded it last night and it says
Health Status =52 %
Performance = 98%
My disc is 5 years and 2 months old .
Can anybody tell me if the prediction that this software does is True or is it just based on certain calculations.
Regards
Old 17-06-2005, 10:48 AM   #16 (permalink)
QA Juggler
saROMan's Avatar
New Version Here
HDDlife v2.1.53
1 really strange Thing..it works as Shareware for 30 days..and after it Turns into a Freeware
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 17-06-2005, 12:13 PM   #17 (permalink)
bharat_r's Avatar
Crazy!!!
they can give it as a freeware from the first itself.
bharat_r is offline
Old 17-06-2005, 08:39 PM   #18 (permalink)
QA Juggler
saROMan's Avatar
WOW...strange...For my Old Seagate HDD with 2 Broken Pins ...its giving me Excellent Condition
also my Other Fujitsu HDD is Ok condition.....
Well bharat_r ...thx a lot for bringing such a Usefull utility to my Knowledge ...
saROMan is offline
Old 17-06-2005, 09:45 PM   #19 (permalink)
i am giving you result of my hard disks. The samsung is 1.5 years old and the seagate is just one month old, the result shows that my seagate is only 40% ok Why? has the dealer given me a bad piece?
And one silly question i donot know how to attach the screen shot in my post please to give reply to this also?
[img=http://img300.echo.cx/img300/599/clipboard023th.th.jpg]
[img=http://img111.echo.cx/img111/7862/clipboard026tu.th.jpg]
shivaranjan.b is offline
Old 17-06-2005, 10:02 PM   #20 (permalink)
harmax's Avatar
go to www.imageshack.us , on the screen upload ur screenshot pic , after the upload theyll give u various links.
cut and paste a link under "thumbnails for forums" on to ur post and voila
WORK EXPANDS TO FILL THE TIME NEEDED FOR ITS COMPLETION
-------- PARKINSON\'S LAW
harmax is offline
