Old 16-06-2005, 06:33 PM   #1 (permalink)
Default strange problem
My config is
AMD 64 3000+ (s939)
ASUS A8N-E mobo
1 GB Transcend Ram DDR400
160GB Sata HDD
Nvidia 6600GT 128Mb PCI-e gfx card
my problem that whenever i start a game after 5-10 minutes my monitor screen goes off and keyboard freezes,but the CPU is still running,even the motherboard LED is still on and all the fans in the cabinet are running.
this only happens when i play games,coz even if leave my pc on for 3-4 hrs this problem doent occur but whenever i start any game this problem occurs.I am using WinXP as my OS
harshagarwal is offline
Old 16-06-2005, 07:06 PM   #2 (permalink)
dinesh_singh
Posts: n/a
it can be a overheating problem.plz check ur cpu and graphic card temp...
by softwares and by touching the heatsink area to confirm the proper cooling and do post here....we will surely find out a solution.
and it must be a overheating problem...
so do post with the result u get.
Old 16-06-2005, 07:19 PM   #3 (permalink)
@dinesh_singh
Sir i have already posted the temperature of my CPU and Gfx card for which u have said that they are cool enough.
www.guessthelogo.blogspot.com
Old 16-06-2005, 07:59 PM   #4 (permalink)
dinesh_singh
Posts: n/a
then check ur ram for errors with memtest....also run heavy applications like modern games and while running them for 5-10 mins check the temp again.
coz if the problem is lying in soft or anyother hardware.....it must have occured at the same time u run those games or app.
also tell me this happen only in games or almost in evrything.
and also lets wait for others to help.
double check ur cables too.
Old 16-06-2005, 08:08 PM   #5 (permalink)
Dark Overlord !!!
rockthegod's Avatar
probably a driver conflict/problem... try re-installing latest drivers 4 ur Gfx/Mobo/Sound/Chipset etc etc and see if the problem is solved.... r u running 1 GB Ram in dual/single channel mode ? ..try changing RAM slots.
C2Q6600@3.2G; eVGA nforce 780i; eVGA 8800 GT 512 MB (650/1900/1620) in SLi; 2 GB OCZ EPP DDR2 8500@1066M; PP&C Silencer 750W; Antec 900
AT&T Tilt WM 6.1 Pro Running Android
Sony PSP 2000 5.0-m33
rockthegod is offline
Old 16-06-2005, 08:16 PM   #6 (permalink)
Is this a new PC? If not, could you run games before without any probs?
Looks like it has something to do with your gfx card. Have you tried updating the gfx drivers?
Also try gaming with all background apps shut down (CTRL+ALT+DEL, shutdown individual apps using task manager). This includes shutting down your antivirus.
Are you running Java based apps in the background? I've had similar probs with a particular version of Azureus (bittorent client) causing display corruption and blank screen when running games on 6600GT. Was a driver <-> jre 1.5.1 <-> azureus conflict. Observed similar corruption when running ProjectX (another java based app, for demuxing DVB streams).
-Keith
Keith Sebastian is offline
Old 16-06-2005, 08:25 PM   #7 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Do check ur RAM module for dust and see if its working fine !! try putting ur RAM in other RAM slots and also clean ur RAM slot with the help of a soft brush also as all the others said , check for overheating problem and/or a driver conflict.
If possible try updating ur motherboard drivers and other updates as possible from this site.... and do post in ur results here and we will find a solution for u Dude
Select ur motherboard model and download the necessary drivers...
http://www.intel.com/products/mother..._motherboards&
cheers n peace...
ashu888ashu888 is offline
Old 22-06-2005, 03:30 PM   #8 (permalink)
My PC is brand new.
I tried changing the RAM modules in all possible combinations.
I even noted the temperatures of my CPU and Gfx card they are as follows
CPU 42 deg celsius on start up and 50deg when i play games.
Gfx card temp is 52 deg on start up and goes up to 77 deg when i played games.
Games which i tried was
1)NFSU
2)NFSU2
3)Enter the Matrix
4)Rise of Nations
Also when i decrease the eye candy stuff from the games my problem does not occur for 30 min to 60 min. but after that same problem occurs.
Old 22-06-2005, 03:45 PM   #9 (permalink)
ur gfx card's getting hot prolly....touch ur gfx card immediately after the prob occurs....if its too hot u need to get some cooling for it
A64 3200 winnie + 512*2 KVR 2.5-3-3-6 2T + MSI K8N SLI platinum - Creative SB Live! 7.1 + Leadtek PX6600GT 550/1125 + 160 GB Seagate N.C.Q. + 320 GB WD + LG 17" CRT
3Dmark05 - 4008 3Dmark03 - 8,983
Ringwraith is offline
Old 22-06-2005, 03:52 PM   #10 (permalink)
i did what Ringwraith said.
the Gfx card is probably hot and is getting heated.
Now what kind of cooling does my gfx card need and how much money i will have to shell out for that.
Old 22-06-2005, 05:21 PM   #11 (permalink)
arre get a HSF of the appropriate size for ur gpu...i once used an extra CPU heatsink i had and it really helped
but first of all check with the original cooling soln for ur gfx card, it might just be the fan's choked with dust! in that case just clean it up or get a high rpm new fan...hope that helps
