Old 16-06-2005, 05:04 PM   #1 (permalink)
Default MSN messanger uninstaller needed...
hi,
recently i have run this autopatcher and then i got this MSN messanger running whenever i start my computer. as i never use this and dosent require it, i want to remove it completely from my computer. how can this be done??? pls advice
Taken
taken is offline
Old 16-06-2005, 05:10 PM   #2 (permalink)
l33t n00b!
Nimda's Avatar
Disable it from running at startup:
http://www.thinkdigit.com/forum/viewtopic.php?t=20956
Remove MSN Messenger:
Run this command from Start | Run.
RunDll32 advpack.dll,LaunchINFSection %windir%\inf\msmsgs.inf,BLC.Remove
If that didn't work, visit this page.
Nimda is offline
Old 16-06-2005, 05:18 PM   #3 (permalink)
QA Juggler
saROMan's Avatar
Get the Windows/MSN messenger Remover Tool from here : http://rapidshare.de/files/2419610/w...mover.exe.html
8-) सारोमान :!: :!: :!:
saROMan is offline
