View Poll Results: Have you updated your bios
Yes 9 64.29%
No 5 35.71%
Voters: 14. You may not vote on this poll
Old 16-06-2005, 03:56 PM   #1 (permalink)
godsownman's Avatar
Default Bios
I have read this many times on the forums.
" I have to update my BIOS"
Can anybody guide me as to what is the advantage, risk , disadvantage abnd how to go about doing it.
Regards and thanks
From the body of one guilty deed a thousand ghostly fears and haunting thoughts proceed !
Visit (http://www.meebo.com)
godsownman is offline
Old 16-06-2005, 04:03 PM   #2 (permalink)
l33t n00b!
Nimda's Avatar
First thing you need to understand is, that BIOS updates are not like updating your anti-virus definitions. BIOS should be flashed only when some new hardware isn't detected or if the update incorporates some important feature you need or if it addresses stability issues etc..
Also, one needs to be careful during the update itself as a power failure in between the update will just render the entire system inoperable. The same holds true for firmware upgrades (for CD-ROM drives etc.). Interrupting which may prevent the hardware component to stop working.
Nimda is offline
Old 16-06-2005, 04:05 PM   #3 (permalink)
godsownman's Avatar
You forgot to say how its done.
Old 16-06-2005, 04:07 PM   #4 (permalink)
mariner's Avatar
why dont u have a look here
http://www.pcmech.com/show/bios/81/
mariner is offline
Old 16-06-2005, 04:14 PM   #5 (permalink)
l33t n00b!
Nimda's Avatar
Hey, can't newer BIOSes be flashed from within Windows itself? Visit your mobo manufacturer's site to know whether that's possible in your mobo. Chances are that there'll be a tool given in the CD that came with the motherboard which will Flash the BIOS from Windows itself.
Nimda is offline
Old 16-06-2005, 05:54 PM   #6 (permalink)
The CREATURE
zodiac_511's Avatar
Personally i did not find any performance gain when i flashed my bios . I feel tht there r more risks than gains .
Yes mobos from gigabyte have this feature
..::: ||ZoDiAc|| ::..
zodiac_511 is offline
Old 18-06-2005, 12:44 PM   #7 (permalink)
mariner's Avatar
download free chapter of oreillys guide on creating boot disk for flashing bios from here
http://techrepublic.com.com/5138-108...tml?tag=search
mariner is offline
Old 18-06-2005, 01:58 PM   #8 (permalink)
Rebooting
Choto Cheeta's Avatar
i use ausu mobo... here with my mobo Cd i got ASUS updater... it can run in any windows Platform.... can download the new BIOS version, back up the old noe & the install the new version.... all this while windows is running....
Choto Cheeta is offline
Old 18-06-2005, 04:18 PM   #9 (permalink)
The Hardware Labs
mohit's Avatar
its very very simple for intel boards also .. just download the bios update for your motherboard from their website (download the self installer) ... and close all programs and run it .. it will update the bios and ur system will be restarted. thats it... just make sure u have a ups though .. coz if the power fails in between this process then u will have to recover ur bios and i dont know how dats done.
mohit is offline
Old 18-06-2005, 09:17 PM   #10 (permalink)
godsownman's Avatar
Thanks Everybody
Old 19-06-2005, 12:09 AM   #11 (permalink)
Ya and mobos from MSI too have this feature
And the good thing abt this is that if a power faliure occurs or some interruption occurs u can again flash ur bios using a bootable floppy created for this purpose
Aviation (Aircraft Maintenance Engineering)
http://www.ame-world.frih.net
Sankalp is offline
Old 19-06-2005, 04:02 PM   #12 (permalink)
MVP in VC++
Hi all,
Now i am having lot of doubts on BIOS.........I am system Intel Original 865GBF Motherboard, P4 2.4Ghz, 1Mb Cache, 256DDR 333Mhz etc...OSes..Win Xp, Win98SE...
  • Firstly, My system hangs or restarts frequently, even while booting.
    My vendor said that it is because of the BIOS property, that It supports only Legacy mode for ATA IDE in Drive Configuration ie under Advanced Section in BIOS.
So will updating the BIOS from Intel Site solves the problem?
  • If i update,which option of updating shalli choose,,i.e Intel Express BIOS update,Intel Iflash BIOS Update or Intel Recovery BIOS...What are their differences...please specify...
    • Finally, if i want to restore back to previous BIOS, What are the options available????
cvvikram is offline
Old 19-06-2005, 07:18 PM   #13 (permalink)
If you have an ASUS or MSI motherboard, it is really very easy to flash BIOS.
Once I hadnt flashed my BIOS properly so the PC wouldnt boot. Instead ASUS EZ Flash popped up and told me to re-insert my floppy containing BIOS or the motherboard drivers CD.
I re-inserted the floppy, and this time it flashed successfully, and my PC stability increased noticeably with the new BIOS.
Last edited by Happy Bytes: Today, at 3:45 AM. Reason: added a signature spreading worm....
AcceleratorX is offline
Old 19-06-2005, 09:19 PM   #14 (permalink)
q3_abhi's Avatar
Advantages - Get some new functions.
Risks- Very risky .
Disadvantages- Flashing your BIOS can be fatal for your motherboard if there is a power failure or surge during the flashing process. If your system is working fine and you don’t find any problems with your motherboard, do not upgrade your BIOS. If you decide to do so anyway, make sure to get some assistance from an engineer or a person well versed in computer hardware.
The above disadvantage was mentioned in 1 of the issues of digit.
If u wanna know how to update ur BIOS, i have a complete procedure.
It was given in DIGIT. If u want it PM me. i have a .doc file.
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
