Old 29-04-2009, 08:15 PM   #1 (permalink)
Default converting .flv files
which is the best format to convert .flv files?I tried combination of avi(video) and lame(audio) in media coder, but the some files converted files defer in audio and video timing.
yogisworld is offline
Old 29-04-2009, 09:03 PM   #2 (permalink)
Wise Old Mouse
mrintech's Avatar
Default Re: converting .flv files
http://www.any-video-converter.com/p...or_video_free/
- MrinTech :)
mrintech is offline
Old 01-05-2009, 01:44 PM   #3 (permalink)
Banned to Spam
Krazy Bluez's Avatar
Location: Look below...not under pants dumbo...use a GPS
Total Video Converter..
My DeviantART page now exists !!!
Krazy-Bluez.deviantart.com
Twitter: http://twitter.com/KrazyBluez
Krazy Bluez is offline
Old 01-05-2009, 03:20 PM   #4 (permalink)
prateek007391's Avatar
correct TVC is the best vedio convertor I ever say
how ever which format u want it to convert
Some times there are special convertor for each format
prateek007391 is offline
Old 03-05-2009, 11:20 AM   #5 (permalink)
thanks guys
I tried Any Video Converter and it gave me good results.
Any Video Converter beats my old trusted media coder because of its simplicity in selecting formats but i felt it was heavier on the system.
i have query about frames per seconds.
If the original file has 300 fps,is it wise to convert it to 800 fsp? or should i go for 300 fps.
Old 04-05-2009, 07:19 PM   #6 (permalink)
thinking di9it'al
di9it's Avatar
Lightbulb Re: converting .flv files
Originally Posted by yogisworld View Post
thanks guys
If the original file has 300 fps,is it wise to convert it to 800 fps? or should i go for 300 fps.
It'll simply add up the duplicate frames in the converted file. Also it'll take more encoding time and will increase the size of the converted file.
So it is not wise to set the FPS in target file greater than the source file. You can't smoothen the motion of any video file by increasing its frame rate.
My Rig:
AMD Athlon 5600+ @ 2.9GHz
Gigabyte M61PME-S2 MainBoard
Kingston 1x2GB 800MHz DDRII RAM
GFX Card : ???
HTC Touch Pro
di9it is offline
Old 04-05-2009, 08:44 PM   #7 (permalink)
thanks di9it,
actually i used the wrong word.used fps instead of video bitrate,but i think what you said, apply to both fps and video bitrate.
