16-06-2005, 10:59 AM
Combodrive or separate DVD ROM
Hi ,
WHich one is better Combodrive or separate DVD ROM and a CD-Writer
Does the combo drive has frequent problems?Also tell me which Combo drive is better Lite-on or Samsung?
16-06-2005, 11:03 AM
The Lite-on Combo drive is good. I have been using it for quite some time now and i have not had any problems. Go for the combo
In the keyboard of life, always keep a
finger on the ESC key
16-06-2005, 11:06 AM
l33t n00b!
If you already have a CD-writer, then going for a standalone DVD-ROM would be the wisest thing to do. On the other hand, if you just have a CD-ROM drive right now, then invest in a CD-RW DVD combo drive. You should go for drives from Sony or LiteOn. My recommended drive would be the Sony CRX320E costing Rs 2,500. Very good drive.
16-06-2005, 11:16 AM
I am Optimus Prime
Can anybody tell me the price of NEW DVD ROM drive?
16-06-2005, 12:08 PM
Samsung-- Rs1500(48x/16x)
Sony- Rs1700(48x/16x)
i completely agree with nimda, i myself got a new DVD Rom (sony) 3 days back.
Be not Thou far from me o Lord....o my strength....haste Thee to help me.
16-06-2005, 01:10 PM
Another Brick in the Wall
Ok i have answerd this mant times.. but doing it again
It's better that u buy a DVD rom and CD writer seperately. There may be problem with lens later on and it's better to have two ROMs instead of one and it costs a 200-300rs more....
See:
DVD Rom drive = rs. 1400
CD writer = rs. 1250
Total = 2700rs. or so
Combo drive = Rs. 2500
For CD writer , get Lite-On 52327S or 5238S or Sony CD writer.
For DVD ROM get Lite-On 165/166
For Combo (in case u want only this) get Lite-On 5232K
17-06-2005, 10:11 AM
I will recommend that you go for separate drives. As you can see, price difference is minimal. So better keep them separate. If one of the things go out of order later, you have to replace only that one thing and not the whole thing. Secondly, you can still have at least some work done if at least one of them is working.
17-06-2005, 09:17 PM
Yes, Go 4 a separate ROMS becoz Combos are giving problem. (Mine is giving).
17-06-2005, 09:22 PM
go for the combo drive. it will read DVDs CDs as well as CD-R, CD-RW.
To follow the path:
look to the master,
follow the master,
walk with the master,
see through the master,
become the master. -Zen
18-06-2005, 12:34 PM
Just Do It
I'd always recommend a Combo drive..... Lite on is the best buy....
18-06-2005, 01:16 PM
I wud say, wait for sometime till dvd-rw prices fall to 3k to 3.5k, or maybe go for it now itself. It wud save ur money on long run coz, one day u might be wanting to burn dvds, by it u can read/ run cds and dvds.
www.Solinweb.net - Webhosting was never so cheap in India!
www.cyclone2k.net - More than wrestling....
www.myspacery.com - Myspace Layouts, Myspace Codes, Myspace Generators, Myspace Tweaks
18-06-2005, 01:38 PM
Just Do It
Didnt u read dr.grudge post, the prices are very less now, below 2k...
18-06-2005, 02:05 PM
The Hardware Labs
he is talking about dvd writers not dvd rom's. dvd-rw's are still costing around 4500/- bucks for 16x writers (any company).
@anilthomas26
go for separate drives and i suggest go for both liteon units. better to keep them of the same brand.
18-06-2005, 02:57 PM
In my opinion go for CD Writer + DVD Rom
coz if one fails due to any reason the other
one will continues to run.
18-06-2005, 03:36 PM
Just Do It
 Sorry didnt check that......
18-06-2005, 03:41 PM
@anilthomas
My friend bought a new LG DVD RW for Rs.3500!!! in Bangalore with bill
So guys hows this LG?
If its good u can buy this itself rite
\"Cogito,Ergo Sum\"
18-06-2005, 03:46 PM
Just Do It
@Whim - Lg is a recommended brand but wud suggest liteon as it probs are less in it..........
18-06-2005, 03:55 PM
Whatever you do, just don't buy a SAMSUNG combo
19-06-2005, 04:26 AM
#19 (permalink)
My sony drive screwed up in just one year's time, I wouldnt recommend anyone to buy a Sony.
Lite-On is OEM for/to for Sony, so I suppose they are just the same.
Samsung's new models of Combo drives (SM-352F, SM-352N and TS-H492A) are good ones. DONT BUY ANY OTHER MODEL OF SAMSUNG COMBO DRIVES THAN THESE THREE.
These three drives from have a redesigned tray, and have given no problems to me so far (I use the SM-352F).
Last edited by Happy Bytes: Today, at 3:45 AM. Reason: added a signature spreading worm....
19-06-2005, 04:34 AM
#20 (permalink)
combo is better if ur low on cash !!!
Cheers !!!
\"Live Life as it comes & Live it KINGSIZE\"
\"Learn From Yesterday,Live For Today & Hope For Tomorrow\".
Bye 4 Now - N_!_r_a_L
19-06-2005, 06:26 AM
#21 (permalink)
combo costs 2300 bucks nd separate ones cost 2250 together.so buy two seaprate ones.
In future if u byu another dvd rw them u would make some cash by selling ur cd writer dude.
so go for two separate drives.
A very good buy is benq dvd rom.Its fast nd silent nd for a cd writer go for a lite on.I ve used it.It rocks nd also carries mt rainer support nd two years warranty
Bombina rocks
19-06-2005, 06:59 PM
#22 (permalink)
The three combo models from Samsung which I mentioned also have Mt.Rainier support.
20-06-2005, 04:55 PM
#23 (permalink)
Just Do It
How does a seperate drive cost lesser than a combo drive ? ??
There was another post here on the same topic where grudge had mentioned that combo drives are cheaper than seperate drives.
U might wanna chck that again.....
20-06-2005, 06:47 PM
#24 (permalink)
I have a Sony CD RW as well as an LG DVD RW.
@AcceleratorX
Man Sony is the best brand around.  Coz Japanese technology rocks.
I would advise to go in for a seperate DVD ROM if you have a CD RW earlier or else if you don't then you can go on and buy a DVD RW+CD RW+DVD ROM Combo drive.
May the source be with you ..
20-06-2005, 10:38 PM
#25 (permalink)
Going for separate drives would be a wise decesion. As many ppl have told u earlier also. This has several benifits as others told but before buying the drive make sure to check that u have the option to connect the two drives i.e. the data cable and power cable.
And u shud go for liteon as samsung drives have problem with the tray.
Aviation (Aircraft Maintenance Engineering)
http://www.ame-world.frih.net
21-06-2005, 04:12 AM
#26 (permalink)
If u r low on cash then u must go for the combos and if u dont fear with the cash then buying the different drives is the best idea Dude!@!
Now i tell u one thing about LG....i ahve a combo of LG.....Gcc-4480b.........working very fine from the last two years !!!!!!!!
and now aslo i can write fully a 700 mb cd in just 2 minutes 50 seconds !!!!1
since u r trying for a DVD RW .......then go for LG....coz LG combo are good and have long lives.............Lite-on is one another sasta choice......................
Always look for these---
Mt. Rainer support
At least 8 mb buffer
Buffer underrrun protection
and your DVD RW which u r taking must have support for dual layered DVD..then that will be better as u can keep more amount of data......
SO HAPPY DVD HUNTING
21-06-2005, 08:01 AM
#27 (permalink)
Mt. Rainer support
What's Mt.Rainer support?
21-06-2005, 12:39 PM
#28 (permalink)
Just Do It
Mt. Rainer is an open industry standard intended to simplify the format and management of CD-RW media .. Mt. Rainer provides true drag and drop CD rewriting and on the fly formatting.....
Cheers
21-06-2005, 01:08 PM
#29 (permalink)
Can anyone tell me that how much cost a dual layer dvd-rw and a normal dvd-rw.
Search this Thread |
