i downloaded a iso file from the net, but its a DVD iso file. i dont have a DVD writer but i do have a CD writer, is there anyway so that i can write it on CDs???? I use WinXP SP2 and Nero.
Shwetanshu Srivastava
Well, that's doubtful. If the iso contains a program/game etc. then obviously it's the DVD version and it won't prompt for things like "Please insert the 2nd CD" and so on. But you can probably install it from the HDD. Install Alcohol 120 and mount the iso on its virtual drive.
You may be able to break up the data into 650Mb chunks and write onto a CD but that'd be a risk.
dude there are plenty of ways of converting DVD related ISO's to CD ones. It all depends on what is content which you have downloaded. As for those who think you cannot make CD's out of say the UT2004 DVD well that is very much possible
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
well actually its GTA San Andreas
