Old 16-06-2005, 08:02 AM   #1 (permalink)
Default Hd activity when Idle mode (most frustrating)
Hi guys..
I don't rmember if I had posted this !
The problem is that I have win XP runinng on a 1.4 ghz machine . And whenever I leave the computer idle for few minz.. there is lots of Hd activities.. I looked for virus (not found) , look for spyware, looked registry, checked the process.. also checked if antivirus is on its work.. but not.. (I have AVG free running).
Earlier it was when I leave the computer and internet is connected but now whenever i leave the computer untoched for few minz.. then there are hd activities.. I am really irritated.. I don't want my HD to develop bad sectors so fast .. (if activities remains same then it can lead to bad sectors so early). SO So..
Any solution .. any idea where to look..
I am happy to provide more info as needed !
~Ricky
» Looking for someone to partner with me in Indian Linux forum
Free domain is available ! I am also at Indian Forums.
Ricky is offline
Old 16-06-2005, 10:04 AM   #2 (permalink)
vishal_bhatia87
Posts: n/a
This is because the XP makes a database of your HDD whenever the computer is in the idle mode. This feature in xp is for fast searching of your files and folders. Download the tweak ui power toy, in that there is the option to turn off or on this feature.
Old 16-06-2005, 10:18 AM   #3 (permalink)
I think its the indexing feature in Win xp just turn it off and everything will b fine !!!
Cheers !!!
\"Live Life as it comes & Live it KINGSIZE\"
\"Learn From Yesterday,Live For Today & Hope For Tomorrow\".
Bye 4 Now - N_!_r_a_L
King_Niral is offline
Old 16-06-2005, 12:25 PM   #4 (permalink)
QA Juggler
saROMan's Avatar
well go to start->run->services.msc ..look for indexing service and disable it..also go to power options and click shutdown HDD after X min of Idle Time...
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 16-06-2005, 12:56 PM   #5 (permalink)
expertno.1's Avatar
if u have ntfs partition
then go to windwos explorer
right clickon the drive
and uncheck the "allow indexing service to index this disk for fast file searching"
expertno.1 is offline
Old 16-06-2005, 01:15 PM   #6 (permalink)
aadipa's Avatar
XP also runs a defrag process in idle mode... that may be the case.
1 aadi + 1 aadi = 1 full ;)
aadipa is offline
Old 19-06-2005, 11:15 AM   #7 (permalink)
Indexing is disable now.. let see if it works.. currently i m going to sit on computer for few hrs .
BTW. I thnk its not defragmentation as I checked the hds fragmentation status and it is untouched at all.
~Ricky
Ricky is offline
Old 21-06-2005, 11:10 AM   #8 (permalink)
Ok this worked perfectly..
Thanku all guys for help and time !
~Ricky
Ricky is offline
