Old 28-04-2009, 10:10 PM   #1 (permalink)
prateek007391's Avatar
Default Ethernet Onboard
I was regularly using broadband at my home
however I removed my broadband from home since 4 months
And now wen I wanted to start broadband at home I found that there is no Ethernet in my PC
My PC is not detecting The onboard Ethernet
What It can be
prateek007391 is offline
Old 28-04-2009, 10:16 PM   #2 (permalink)
lost in my world
yippee's Avatar
Default Re: Ethernet Onboard
drivers are installed correctly?
yippee is offline
Old 28-04-2009, 10:18 PM   #3 (permalink)
Yes I tried to install it but still windows says it is not able to open the device
or start the device, check if the device is connected properly
Old 04-05-2009, 01:53 AM   #4 (permalink)
GOD
vaibhav_jain's Avatar
maybe ur ethernet port is malfunctioned. Use Pcie lan card.
Vaibhav Jain
vaibhav_jain is offline
Old 04-05-2009, 02:04 AM   #5 (permalink)
This kinda problem was faced by me in case of my onboard audio card.
Later i came to know that my audio card is blown up.
{Intel Q6600|Palit gtx 260|Asus P5NE SLI|Transcend 2GB DDR2 800MHz|Seagate 500Gb SATA2 7200.12|Genuine Win Vista Ultimate|Microsoft wireless k/m|Lenovo S9|Nokia 6270|Vodafone 227|Tata indicom c3000}
mayanksahni is offline
Old 04-05-2009, 02:08 AM   #6 (permalink)
Old 04-05-2009, 05:07 PM   #7 (permalink)
GOD
u can also connect ur modem via usb
Vaibhav Jain
Old 06-05-2009, 10:18 PM   #8 (permalink)
Assuming you're using Windows, does the ethernet device show up in Device Manager? If not, did you check to see if it's disabled in BIOS?
If it's enabled in BIOS, maybe it has gone defective as someone else suggested. In that case, you'll have to install a PCI LAN card. At least it's cheap - only 150-200 bucks.
pimpom is offline
