Hi Guyz ,
I am planing to join a famous multimedia institution for being a pro in the field of vfx and animation so i will gonna runn maya 3dmax apple final cut Apple shake Adobe Photoshop Adobe Premire etc and as we all know they are resource hungry software so i had plan to buy a Machine for them.
The configuration for my pc is as follows:
Processor-
intel core i7 P940 2.98GHz or intel Core i7 P920 2.66GHz
Motherbord ASUS P6T DElux Or gigabyte bords (
it should have Full upgrade option and future proof 2 way SLI is a must 3 way would be better)
Memory - CORSAIR DDR3 XMS3 4GB (2 X 2GB)
1600MHz or 1333MHz
HDD-
WesternDigital Caviar Blue 1 TeraByte X 2 or 500GB X 2
(Should suport RAID 1)
Optical Drive -
Blueray/DVDR+RW 2DL Writer
PSU- Cooler Master 600-eXtreme Power
CPU Cooler -
Thermalright CPU Cooler IFX-14 or Thermalright Ultra-90-775
Cabinate -
Antec With transperent side panel must
TV tunner card internal
Pinacle
GPU -
Nvdia Quadro Fx 3800 or any Quadro Fx card with
SLI support GDDR3 (
1GB or 512 Mb)
Monitor - SAMSUNG 2033SW 20" X 2 SAMsung 22" X 2
(must be full HD 1080p)
Design Tablet -
WACOM 8" X 6" or any good one
Keybord - Full multimedia keybord from Logitec
'NOMOUSE plese'
External HDD- Western Digital minimum 500GB or 1 TB
Speakers - CREATIVE 7.1 or 5.1
Headphone - ANY Good Quality that give every detail of soung for both high and low pitch...
if possible
Liquid Cooling for entair system
I NEED THE SYSTEM TO BE FUTURE PROFF AND ATLEAST RUN ALL THE GRAPHIC DESIGNING SOFTWARE LIKE MAYA 3 D MAX and LATEST GAMES ATLEAST 6YEARS WITHOUT ANY ISSUE THEN THE SYSTEM CAN BE UPGRADED SO IT SHOULD HAVE LOADS OF UPGRADE OPTION TOO AND AFTER ALL VALUE FOR MONEY SHOULD BE ALSO KEPT IN MIND.
ONE MORE THING STRICKLY IF THE RAM IS IN DDR3 THE ENTIRE SYSTEM SHOULD BE in DDR3 THERE SCOULD NOT BE ANY COMPATIBILITY ISSUE LIKE ONE COMPONENT AT DDR3 THE OTHER ONE AT DDR2
The Bold are my
must have or
first preference feture ok so now its YOU who gonna help me to take decission is my config match edge to edge? is there any loop hole ? if then where?
give me your views MY budgect is 1.25lac +- 25k and Do tell me can i buy
this
Nvidia 3D vision Kit "
and as i stay in kolkata where i will get all this stuff as every shope here dosent keep such things please help me my Digitian Brothers and sisters i will also like to hear from digit team members though they are too busy but i will be very thankfull if they spare a part of there most valluable time and help me to choose my components for my Dream mashine....
