I already posted about this.So i post the same again.
So if u need to transfer: ( from phone to PC or vice versa)
You will need a bluetooth (bt) adaptor for ur PC. You have two options:
1. A card that plugs into the PCI slot of a PC and has a external antenna for communication-- cumbersome to use.
2.USB bt adaptors:these tiny devices plug into ur USB port and work as a interface for bt comm with lappy or cellphone.
The advantage of using a USB adaptor is that u can remove it when not needed and plug it into another PC or lappy without any hassle.
These adaptors are rated on the range they cover:a 10 m adaptor will cost rs 1000, where as a adaptor with 100m range will cost u rs1800.
