Old 25-04-2009, 12:30 PM   #1 (permalink)
Smile HJSPLIT:: help.
friend,
i have downloaded some flash video tutorials from mediafire, those were in
001 format and i joined those using hjsplit successfully, the result was
there were two files 400mb and 150mb in unrecognised format. like the file name is[Pchwmf8cd1] and there is no extension, for two files i.e for 400mb as well as 150mb i tried changing them to rar,mov,iso flv,etc but no result. please help
Regards,
Suriya.
sadhu is offline
Old 25-04-2009, 12:54 PM   #2 (permalink)
Default Re: HJSPLIT:: help.
Which is that unrecognised format ?
Please provide a screenshot of the file as well as the complete name of the .001,.002 amd the final files
cyberxtremer is offline
Old 27-04-2009, 12:25 AM   #3 (permalink)
aswin1's Avatar
Try the extension flv for flash videos.
aswin1 is offline
Old 27-04-2009, 03:34 PM   #4 (permalink)
Gracias Senor
dreams's Avatar
^^+1
it shuld b flv
iPT 2G(S) - 8GB - JBn
iPhone 3GS 16GB - JBn
MAC OSx86 on P4 2.4Ghz
HTC Touch - Elfin - P3452 - WM 6.5
- Dont Dre@m... Juz Chase it -
dreams is offline
Old 29-04-2009, 07:33 AM   #5 (permalink)
Call me D_J!
Disc_Junkie's Avatar
Originally Posted by sadhu View Post
friend,
Regards,
Suriya.
Is the "Hide extensions for known file types" enabled in Folder Options-->View. If yes, then disable it and check the extension. And btw did u try to play them using any player?
ASUS K42JA-VX032D RAWKS !!!!!!:grin:
Disc_Junkie is offline
- by Krow
