08-09-2004, 07:10 PM
help with JAVA
hey u guys,
im in a fix,m i got this problem with java..
Whenver i try to run a progrm, i get an error saying "NoClassDefFoundError", although the program is compiled well!!!
Plz help me, im running windows XP, java was runnning well before on XP, i lately am experiencing this problem,.....
Only one thing is certain -- that is, nothing is certain. If this statement is true, it is also false
---ANIRUDH
08-09-2004, 07:26 PM
add a variable called CLASSPATH in your local variables indicating the location of your class file and also the jre/jdk class files.
**** happens
09-09-2004, 01:35 AM
means that your classpath is not set correctly. Make sure your JAVA_HOME is set up right before you run the startup scripts.
\"99 little bugs in the code, 99 bugs in the code, fix one bug, compile it again, 148 little bugs in the code. 148 little bugs in the code....\"
09-09-2004, 01:36 AM
post you're source code,
it will help to solve you're problem & and let me know what you doing with?
09-09-2004, 11:59 AM
FooBar Guy
for UNIX:
add this to your /etc/profile
CLASSPATH=/usr/jdk/jre/lib/rt.jar:.
export CLASSPATH
for WinXP,
add the path to your CLASSPATH environment variable.
CLASSPATH=C:\jdk\jre\lib\rt.jar;.
Notice the dot in the end... it refers to the class file that is in ur current directory...
09-09-2004, 07:12 PM
well i tried everything you guys suggested, but of no use
my java folder is in D:/java
bin is in D:/java/bin
all my programs which used to compile earlier no longer work! im in a fix plz helpme
---ANIRUDH
---ANIRUDH
10-09-2004, 01:48 AM
If you can't compile, your PATH probably needs to be set.
c:/>set PATH=%PATH%;d:/java/bin
You can permanently set this by going to (WinXP) Start>Settings>System, Advanced tab, Environmental Variables
What do you get if you type in
java - version
If your system can't find this, it is a path problem. You can either set the path, or make it explicit:
d:/java/bin/javac MyClass.java //to compile
d:/java/bin/java -cp . MyClass //to run
10-09-2004, 07:39 PM
well i managed to mess around and get it working,.... thanx for all the help guys!!!
--Anirudh
---ANIRUDH
11-09-2004, 01:04 AM
can you please post the full error stack you got?
with source code.
11-09-2004, 01:06 AM
welcome no problem.
Search this Thread |
