Old 15-06-2005, 09:43 AM   #1 (permalink)
Default removing partition
I hav windows 2000 on C drive and windows xp on D drive. Now i want to remove XP. How do i do it. Can smeone help me?
ankit_biz is offline
Old 15-06-2005, 09:55 AM   #2 (permalink)
l33t n00b!
Nimda's Avatar
1- Log into Windows 2000 and format D:
2- Boot using the Windows 2000 CD and goto the Recovery console
3- Type the following commands at the prompt.
fixboot C: [Enter]
fixmbr [Enter]
4- Reboot.
More info on the Win 2000 recovery console here
Nimda is offline
Old 15-06-2005, 12:41 PM   #3 (permalink)
thanx and if i want to keep xp and remove 2000 then??
Old 15-06-2005, 01:23 PM   #4 (permalink)
Rebooting
Choto Cheeta's Avatar
this will only help u if u r on FAT system.... as i found NTFS doesnt follow that rule.....
any one knows the how to deal with this question if the format is NTFS??
Choto Cheeta is offline
Old 15-06-2005, 01:34 PM   #5 (permalink)
l33t n00b!
Nimda's Avatar
That shouldn't be too difficult
Replace the following terms in my first post:
1- '2000' by XP
2- 'C:' by 'D:' and vice versa
Just one suggestion though, whichever OS you plan to have, make sure it is installed in C:. It's not a good idea to have Windows on D: and games or songs on C:.
Nimda is offline
Old 15-06-2005, 01:43 PM   #6 (permalink)
Rebooting
@nimda
Have u seen my question??
Old 15-06-2005, 01:50 PM   #7 (permalink)
l33t n00b!
Nimda's Avatar
Hmm.. Long time since I played with Win 2k and XP installations so I'm not fully sure but if I remember correctly, I faced no problems with NTFS.
What error are you getting, Saurav? The dual boot screen not going away? BTW, my name is also Saurav
Nimda is offline
Old 15-06-2005, 04:14 PM   #8 (permalink)
Rebooting
well i tell u indetails....
I have 80GB HDD with 10GB each C, D, E, 15GB F & G and a 20GB H partition....
the pramary dos partion is drive c:.... all otheres r logical drives....
C, D, E, G is in NTFS format..... & F, H is FAT32.....
now i had wind2K Server SP4 install in C: & winXP Pro SP2 in drive d:....... some times back i installed win Server 2003 SP1 (Fresh install, no upgrad...) on the c: drive....
system didnt had any problem of ditecting the OS change... BOOT.ini changed it self to config as for those to new OS....
well when i wanted to return to the win2k SP4... i just went with a quick format of the drive c: & install the fresh copy of the OS.....
as win2k is elder than XP thats why i lost the dual boot menu...
so i tryed this.....
Fixboot, fixmbr, bootcfg, copying the ntldr & ntdetect.com from xp sp2 cd...
earlyer i tryed this with FAT32.... there it worked.... but with NTFS i get this error.....
ntldr is compressed
press ctrl_alt_del to restart
Old 15-06-2005, 06:22 PM   #9 (permalink)
l33t n00b!
Nimda's Avatar
This may not be due to NTFS. It could very well be a coincidence that it worked in FAT32. Logically speaking, that error should be solved using the following commands in the recovery console.
CD \
ATTRIB -C NTLDR
Anyway forget it. I won't be able to help much unless I have direct access to the PC since this problem is not very common.
Nimda is offline
- by Krow
