Old 14-06-2005, 02:54 PM   #1 (permalink)
ClubHost.in
cancer10's Avatar
Default Antispyware
Is there any AntiSpyware program that will sit on my status bar and monitor if there is any spyware/adware/trojan/backdoor attacks on my PC?
please give the download link for the same....thanx
cancer10 is offline
Old 14-06-2005, 03:53 PM   #2 (permalink)
The Hardware Labs
mohit's Avatar
what u need is an antispyware program with real-time protection. download ms antispware from the following link and protect ur pc. its a good anti spyware program with effective real time protection.
http://www.microsoft.com/downloads/d...displaylang=en
mohit is offline
Old 14-06-2005, 04:02 PM   #3 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Wat abt the Ad Aware SE Personal edition for removal of spyware !! coz i am using the same software...is it good or really bad in removing spy/adware ??????
ashu888ashu888 is offline
Old 14-06-2005, 04:06 PM   #4 (permalink)
The Hardware Labs
mohit's Avatar
yup ad aware is also highly recommended but it does not have real time protection ... it is a very good program with good detection rates. download both ms anitspyware and ad-aware se personal ..it will be worth it.
mohit is offline
Old 14-06-2005, 06:20 PM   #5 (permalink)
i recommend a combination of Spybot S&D, Ad-aware SE and MS Antispyware
Shwetanshu Srivastava
shwetanshu is offline
Old 14-06-2005, 10:18 PM   #6 (permalink)
Hi,
I use Micorsoft Antispyware, Spyware doctor and Spybot Search And Destroy along with Zone Alarm Pro security suite as a firewall - These all reside in the system tray. I think these are best to find and remove any spyware. Also, if you don't have any firewall, then use Zone Alarm. It is the best.
vmp_vivek is offline
Old 15-06-2005, 04:58 AM   #7 (permalink)
Fresh Stock Since 2005
Adaware SE is a very good Spyware detector and remover but the personel free edition does not have Real-Time Protection (ad-watch)............
And your Location really makes me sick............ I did not find you in between earth and mars............... Where in the hell r u??
http://www.khattam.info
khattam_ is offline
Old 15-06-2005, 05:04 AM   #8 (permalink)
Originally Posted by vmp_vivek
Hi,
Oh I didn't know that ZA Pro Security Suite removed Spywares........... LOL
And yeah ZA Security Suite is the best Firewall+Antihacker but Kerio is better................ coz it gives better application awareness.................
@cancer 10
Yeah MS-Antispyware is good but AVs such as Norton and KAV(with extended database) also monitor and remove spywares and adwares..............
khattam_ is offline
Old 18-06-2005, 01:28 PM   #9 (permalink)
Just Do It
Charley's Avatar
Hi,
And isnt there a prob if all these run together ??
Charley is offline
Old 18-06-2005, 10:15 PM   #10 (permalink)
Distinguished Member
anandk's Avatar
use spywareblaster and spywareguard. if u have less ram
use spywareblaster & ms anti-spyware if u have more ram
all are freeware and available at www.download.com
keep an extra adaware/spybot to help u with the malaware detection.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 18-06-2005, 10:43 PM   #11 (permalink)
Biplav's Avatar
just go for microsof anti spyware!
thats the best real time protection.
ad aware personal doesnt offer ad-watch but i had downloaded the pro version (cracked ofcourse) but the ad-watch protection was not all that gr8
ms anti spyware detected loads of spywares that adwatch couldnt.
"Try again, fail again, fail better" - Samuel Beckett
Biplav is offline
Old 19-06-2005, 03:58 AM   #12 (permalink)
there is no problem running together all these achacko@dataone.in
consider them a good option for ur pc
"Gordon Freeman is a mermaid, he obviously traded his legs for his voice."
Old 19-06-2005, 10:53 AM   #13 (permalink)
Just Do It
Charley's Avatar
I happend to see the same article in another website where the respondents said that if many of the spy softies are loaded in sys start up then it will not detect the stuff.
So then I can load KAV, AVG, Spybot, Spyware guard & blaster in the Sys Start up, isnt it ?? 8)
Charley is offline
Old 19-06-2005, 07:52 PM   #14 (permalink)
yeah u will NOT have any problems for my choice of spyware softwares for ur system startup .... they WILL detect the spywares perfectly
Old 19-06-2005, 10:54 PM   #15 (permalink)
Use ad-aware or ms antispyware beta.They are best.Im using it.
What doesn't destroy me, makes me stronger.
jamifahad is offline
Old 20-06-2005, 12:56 AM   #16 (permalink)
ne real time protection providing antispyware for win98se cause ms antispyware soesn't support win98se?
supersaiyan is offline
Old 20-06-2005, 09:31 AM   #17 (permalink)
ClubHost.in
cancer10's Avatar
Link plz????
cancer10 is offline
Old 20-06-2005, 12:39 PM   #18 (permalink)
Hey guys, i recently downloaded the MICROSOFT ANTISPYWARE BETA version 1.0 from the Microsoft site but after the downloading process, the s/w says that it will expire in 41 days !!!
So shud i again reinstall the MS ANTISPYWARE BETA version 1.0 or wat??? plz suggest me as how can i keep on using this s/w as long as i desire !!! if i cant install it after it has expired after 41 days then wat r the other alternatives ??? Do i hv to pay for this s/w to keep using it for future use after its trial version expires???
plz help and suggest........
cheers n peace....
Old 20-06-2005, 01:13 PM   #19 (permalink)
The Hardware Labs
mohit's Avatar
@ashu888ashu888
dont worry dude everyone is having the same version which will expire on july 31 , 2005. even if u reinstall it , the problem wont be solved. ms had released the beta version for a long time testing and finally that period is reaching its end. i dont know if it will become paid but there were rumours of ms releasing anti virus and anti spyware for a fee and not for free. lets see what happens. btw this was the beta1 , i hope they release another beta version for some more time atleast till longhorn is released
mohit is offline
Old 20-06-2005, 02:23 PM   #20 (permalink)
ClubHost.in
cancer10's Avatar
Originally Posted by mohit
@ashu888ashu888
Amen
cancer10 is offline
Old 20-06-2005, 02:31 PM   #21 (permalink)
Just Do It
Charley's Avatar
Originally Posted by cancer10
Link plz????
I really dont recall it as I was on a rampage hunt as these didnt work on my sys.....
Charley is offline
Old 20-06-2005, 04:38 PM   #22 (permalink)
Just Do It
Charley's Avatar
I'm gonna proceed and format my drive tomm and then install all these on the startup
Tks
Charley is offline
Old 24-06-2005, 02:11 AM   #23 (permalink)
ok dude
- by Krow
