Old 20-04-2009, 03:47 PM   #1 (permalink)
Question How to create autorun cd
Hi
I want to create a cd. When i insert it in to the drive it automatically copy specific files in cd to the desktop of the computer.
Please tell me how can i do this.
sdhiraj1 is offline
Old 22-04-2009, 09:40 PM   #2 (permalink)
Banned to Spam
Krazy Bluez's Avatar
Location: Look below...not under pants dumbo...use a GPS
Default Re: How to create autorun cd
Use Longition Autorun Pro enterprise...it will allow you to do that...
My DeviantART page now exists !!!
Krazy-Bluez.deviantart.com
Twitter: http://twitter.com/KrazyBluez
Krazy Bluez is offline
Old 22-04-2009, 10:04 PM   #3 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Create a Rar SFX exe to extract files to desktop in silent mode. Then make a autorun.inf in root of CD with following Command
[autorun]
OPEN=autorun.exe
ICON=autorun.exe
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 25-04-2009, 09:00 PM   #4 (permalink)
Banned to Spam
^ he he..loolll...
Old 26-04-2009, 01:39 PM   #5 (permalink)
Thanks for your great value replies.
But my next question is
How can i do that in bootable CD?
sdhiraj1 is offline
Old 27-04-2009, 09:42 PM   #6 (permalink)
clmlbx's Avatar
Forum Error
Athlon II X4 635 @ 2.9Ghz   Gigabyte GA-MA785GMT-US2H   Kingston 2x2 Gb 1333Mhz DDR3   WDC 500Gb Green   Palit GTS 250 512mb   Tagan 500W   Samsung B2030   Lg DVD Writer
clmlbx is offline
Old 27-04-2009, 09:44 PM   #7 (permalink)
clmlbx's Avatar
for bootable nothing special needed just do it same. create autorun.inf
[autorun]
OPEN=name of file with extention and path (if in subfolders)
ICON=autorun.exe (optional)
clmlbx is offline
Old 27-04-2009, 09:50 PM   #8 (permalink)
Host4Cheap.org
Originally Posted by clmlbx View Post
for bootable nothing special needed just do it same.create autorun.inf
[autorun]
OPEN=autorun.exe
ICON=autorun.exe
I dont know how but the above aint right aswell :-P
Old 27-04-2009, 10:12 PM   #9 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
[autorun]
OPEN=autorun.exe
ICON=autorun.exe
[autorun]
OPEN=autorun.exe
ICON=autorun.exe
Spot the difference!!
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
Kl@w-24 is offline
Old 27-04-2009, 11:29 PM   #10 (permalink)
TheSaint
NucleusKore's Avatar
I have used this, it's very good. Freeware.
http://www.snapfiles.com/reviews/Aut...ncdassist.html
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 28-04-2009, 12:05 AM   #11 (permalink)
clmlbx's Avatar
Well I have created cd's & dvd's like that and a lott.
For coping file I had made ".bat" files and then added to autorun.inf
and I have done this lott of times
clmlbx is offline
Old 28-04-2009, 12:14 AM   #12 (permalink)
clmlbx's Avatar
and that my first post was forum error
clmlbx is offline
Old 28-04-2009, 07:33 AM   #13 (permalink)
Cool Re: How to create autorun cd
Heres the trick
If you wanna make a autorun file for that CD you are ready to burn just read this...
1) You open notepad
2) now you writ: [autorun]
OPEN=INSTALL\Setup_filename.EXE
ICON=INSTALL\Setup_filename.EXE
Now save it but not as a .txt file but as a .inf file.
But remember! The "Setup_filename.EXE" MUST be replaced with the name of the setup file. And you also need to rember that it is not all of the setup files there are called '.exe but some are called '.msi
3) Now burn your CD with the autorun .inf file included.
4) Now set the CD in you CD drive and wait for the autorun to begin or if nothing happens just double-click on the CD drive in "This Computer"
kickout1434 is offline
Old 29-04-2009, 10:28 AM   #14 (permalink)
Hey guys please read my first post.
I dosen't want to open any program and icon when i insert CD in drive \ boot from CD.
I just want "Automatically copy the files from CD to the desktop screen of computer, when i insert CD in drive or boot from CD ( from bootable cd) ".
I got answer for inserting CD in drive by Sukhdeep Singh .
I still want the answer of How can i create a CD which automatically copies some files to the desktop screen of pc when i boot from CD.
sdhiraj1 is offline
- by Krow
