HI
I TRIED TO INSTALL THESE SOFTWARE BUT THEY FAILED TO INSTALL
MS ANTISPYWARE
ITUNES
BR QIUZ MASTER (FROM DIGIT)
DUE TO THIS ERROR:-
ERROR 1327 INVALID E DRIVE
COMPUTER IS NOT MODIFIED TRY IT SOME OTHER TIME
E DRIVE IS SECURED FOR MY EXTERNAL HDD & I POD.
http://www.himtuna.com/
http://www.himanshuthakur.com/
Do good to be good !
couldnt possibly be, unless u have installed your os on e drive. installers usually take the system drive for default installations.
anyway try it again, and this time replace it with the drive alphabet of your choice.
