Old 13-06-2005, 12:44 PM   #1 (permalink)
Default Service Controller XP - Boost Your eXPerience
Service Controller XP, A One of its kind Free Software which will let you to Start, Stop, Pause services and change their startup type, which will not only give a boost to your system performance but also result in higher system security. It will guide you with recommended settings for Safe, Gaming and Internet gateway PC-configurations, and provide you with detailed information about a particular Service. A must for Every XP/NT User.
Main Features Include -
(1). Foolproof, now you cannot disable/Stop system critical services.
(2). Suggested settings listing for all services.
(3). Easy Access to commands using right-click menu.
http://freeware-alternative.uni.cc/d...roller-xp.html
Deepesh Agarwal,
http://www.freeware-alternative.uni.cc/
Visit website for Award-Wining Freeware\'s
deepesh83 is offline
Old 30-06-2005, 07:07 PM   #2 (permalink)
Distinguished Member
anandk's Avatar
hey u seem to be the author of this utility ! well great.
but in winxp/sp2, i go to start>control panel> admin tools>services, & i do the same thing. does it do anything more ?
have downloaded it and will try it. thnx !
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 30-06-2005, 07:49 PM   #3 (permalink)
Default Re: Service Controller XP - Boost Your eXPerience
Thanks man, really appreciate it.
-k
Keith Sebastian is offline
Old 01-07-2005, 09:09 AM   #4 (permalink)
Default Yeah!
Yeah, but It does provide you with a lot more information, ease of use, a friendly interface as well as SUGGESTION on what to enable and what to not, which default windows version does not, A novice can disable system crtical services which can make system unoperable, but this soft. prevents that also.
Deepesh Agarwal,
Old 05-07-2005, 06:47 PM   #5 (permalink)
anandk's Avatar
ya i agree with u. downloaded it; am using it. thnx agn !
Microsoft® MVP
anandk is offline
- by Anorion
- by ax3
