Old 13-06-2005, 12:29 PM   #1 (permalink)
siriusb's Avatar
Default Ventilation for elegance
Hi,
I just assembled a amd64 3200+ (@2150GHz) system on a asus a8ne motherbord onto a zebronics elegance cabinet. The cabinet came with two side panel exhaust fans and a grill at the back side of the cabinet (no fan).
I checked the cpu temperature with asus's Ai booster software. The temperature dropped a few degrees when I installed a exhaust new fan (salvaged from my old system) at the back.
I noticed further drop in temperature when I made the lower side fan as intake and kept the upper side fan as exhaust (since I thought hot air rises). But still my cpu simmers at 39 to 44C while idling and 49 to 54C when at 100% (depending upon the time of the day.) (For 100% load, i used superPI @ http://files.extremeoverclocking.com/file.php?f=36)
Are the temperatures normal? Do i need to use some new thermal paste? Coz I accidentally touched the paste when I was installing the cpu
If anyone has an elegance case and has a good case fan arrangement, do reply. This stuff is extremely noisy and my room is HOT.
siriusb is offline
Old 13-06-2005, 12:43 PM   #2 (permalink)
These are EXTREMELY good temperatures for your CPU. I am running my athlonxp 1600+ (OC'd) at around 68 degrees at full load, with LOAD's of fans and HEAVY heatsinks...
Rajeev V Nair
premrajeev is offline
Old 13-06-2005, 01:30 PM   #3 (permalink)
siri the temp is damp okk........we run athlon series at 60+ under load or no load(for me)....yours is fine......need not worry dude
magnet is offline
Old 13-06-2005, 03:35 PM   #4 (permalink)
Those temps are pretty good for chennai. No need for concern.
I have 1 fan blowing out of my case and full load temps with a 10%(200Mhz) overclock are no more than 58C. But summer's out here, else they would've been over 60C for sure.
Keith
Keith Sebastian is offline
Old 14-06-2005, 10:41 AM   #5 (permalink)
siriusb's Avatar
Wow, thanks a bunch. I guess that's the difference between 130nm and a 90nm chip. I guess I will stop with 3 case fans for now.
Actually, now I am OC'ing only if I have to play or render something. For browsing and stuff, I bring down to standard freq. Asus's windows based OC rocks
siriusb is offline
Old 18-06-2005, 01:11 PM   #6 (permalink)
Sorry for my ignorance: How to check the temperature of my laptop form windows XP. One of my friends suggested to go to the CMOS or BIOS at boot up, but I want to see the temperatue in windows.
IBM ThinkPad R51 2887 LQ3 [P M 715(1.5GHz), 256MB RAM, 40GB 4200rpm HDD, 15in 1024x768 LCD, Intel Extreme, 24x10x24x/8x CD-RW/DVD, Intel PRO/Wireless 2200BG , Modem(CDC), 10/100 Ethernet(LOM), UltraNav, Secure Chip, 6 cell Li-Ion battery, WinXP Home.]
super_i_man is offline
Old 18-06-2005, 02:42 PM   #7 (permalink)
siriusb's Avatar
Almost all motherboards come with their own temp monitoring software in their driver cd. If yours didn't come with one, u can search for "motherboard monitor". I guess it's an ok software.
siriusb is offline
Old 18-06-2005, 08:54 PM   #8 (permalink)
Hey, try enabling Cool 'n Quiet. So, even if you've OC'ed the proc will run at 50% clock speed during browsing and other mudane ops. No need to worry about temps.
1. Install latest AMD processor driver.
2. Enable Cool 'n Quiet in BIOS
3. Change Windows power management to "Minimum power management"
Step 3 is very important in making AMD C&Q work.
Keith
Old 18-06-2005, 09:30 PM   #9 (permalink)
siriusb's Avatar
I am not sure if I can OC with cool and quiet enabled. The Asus Ai booster with which I OC says it won't start if C&Q is enabled. Are u sure you can OC and do C&Q at the same time. I would very much like to do that.
siriusb is offline
Old 18-06-2005, 11:04 PM   #10 (permalink)
OC via BIOS. ASUS has simple OC options in BIOS. For Eg: OC system by 1% - 10%. Manual OC is possible too, where you set different parameters individually.
This is w.r.t. my K8N board. Your's may differ. Check manual.
-Keith
Old 18-06-2005, 11:20 PM   #11 (permalink)
siriusb's Avatar
Thanks, but though my asus a8n-e has AI overclock and NOS, I OC manually (mainly because my stable clock is between those 8% and 10% options).
But I was confused why AI booster doesn't allow me to OC with C&Q on, in windows. I haven't considered OCing from the bios. Thanks for suggesting. I'll try this.
siriusb is offline
Old 19-06-2005, 03:20 PM   #12 (permalink)
ya to use AI booster you need to disable C & Q .... otherwise it wont start...
its my gift....
its my curse....
who am i??
i`m spiderman....2!
godzi_85 is offline
- by Anorion
- by ax3
