I'm using WIndows XP SP1. I have 3 Harddisks in my computer 40GB, 80GB, 80GB .I have 4 partitions on my single physical drive: C, D, E, and F.
One time system I attach other 40 GB hardisk & copy data to my 40 GB HDD and ejected that than after restart system.
Than Prob. Created One partition of 80 GB's One pation 18 gb has converted in RAW and all my data not shown that partition, and other patitions of that HDD is ok. no prob in that... .. So .what can i do to get data back//
I used this thing than after also . ..
CONVERT is not available for RAW drives.
Press any key to continue . . .
When using CHKDSK it responded:
The type of the file system is RAW.
CHKDSK is not available for RAW drives.
It doesn't work/ ..
Any idea how to get my data back?
Thanks before
Sharad
[/url]
