Old 12-06-2005, 10:06 PM   #1 (permalink)
Default PROBLEM WITH .NFO FILES
WHENEVER I TRY TO OPEN A .NFO FILE I GET AN ERROR MESSAGE SAYING:
SYSTEM INFORMATION CANNOT OPEN THIS NFO FILE.THIS MIGHT BE CORRUPTED OR AN UNRECOGNIZED VERSION.
THEN SYSTEM INFORMATION SIMPLY SHOWS COMPUTER SUMMARY.
WHAT DOES THIS MEAN?
WHAT CAUSES THIS ERROR
HOW CAN IT BE CORRECTED?
drsood123 is offline
Old 12-06-2005, 10:19 PM   #2 (permalink)
bharat_r's Avatar
nfo files can't be opened like that I think.Get an NFO viewer.Click here for DAMN NFO Viewer.
Try searching google for "nfo viewer"
bharat_r is offline
Old 12-06-2005, 11:40 PM   #3 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
ALso use Notepad++. It is a great software and replacement of Notepad and opens nfo files also.
http://notepad-plus.sourceforge.net/uk/about.php
navjotjsingh is offline
Old 13-06-2005, 12:42 AM   #4 (permalink)
- Snake -'s Avatar
maybe the files you are trying to see are from a software and contains some iNFOrmation about it... as suggested above try using notepad to see what it contains....
I am a self thought geek and a wanna be Entrepreneur!
My Website | Github | Follow me on Twitter
- Snake - is offline
Old 13-06-2005, 10:14 AM   #5 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
Just use plain old Notepad to view those .NFO files.
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
Kl@w-24 is offline
Old 13-06-2005, 03:52 PM   #6 (permalink)
expertno.1's Avatar
just open the wordpad
click open
select the nfo files
click open
u r done ...as simple.....as........taking a chocklate form a child
expertno.1 is offline
Old 13-06-2005, 04:10 PM   #7 (permalink)
the genuine nfo files open in sys props and these other types in notepad
cyberia.in is offline
Old 13-06-2005, 09:21 PM   #8 (permalink)
QA Juggler
saROMan's Avatar
well though notepad can be used to view nfo files but nfo viewer is used to see all the art work done properly..you can also get this effect in Notepad
1st : right click on nfo file select Choose from list ..if this option is not shown keep Shift key pressed b4 pressing right Click..
2 go to the list ..select notepad as default app..check the use this app every time to open the file...thus now when ever u click a nfo file it will be Opned in Notepad..
3 if u want to see the true artwork of nfo file just change the Font to TERMINAL.....
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 13-06-2005, 09:25 PM   #9 (permalink)
l33t n00b!
Nimda's Avatar
Check out this page. It has a lot of NFO related software.
Nimda is offline
Old 13-06-2005, 11:12 PM   #10 (permalink)
Rebooting
Choto Cheeta's Avatar
yup.... he needs this suggestion..... i guyes for his use.... which we dont talk here....
Choto Cheeta is offline
Old 13-06-2005, 11:53 PM   #11 (permalink)
Ashwin Saxena
Posts: n/a
I think you got answer from above posts.They are really helpfull
If not than Open notepad.Click on File.
Click on Open file.Locate your file.Than clik open in dialog box.
You have doned.
I know you are not a kid but this is a stap by stap trick.
Old 14-06-2005, 07:13 AM   #12 (permalink)
Ignorance is BLISS !!
DAMN NFO Viewer can be of help in this regard !!
rajkumar_personal is offline
- by Krow
