Old 06-04-2009, 08:08 PM   #1 (permalink)
Red face Problems in opening Drive Folders
Hi, Could you please help me to sort out the problem that after clicking of any of Drive icons i.e., C, D, E or F in 'My Computer' page, it doesn't open instead 'Open with' window opens asking to open with which program. Before this, I'd downloaded a office software in my office pc. Please suggest the solution.
Kerry is offline
Old 06-04-2009, 08:32 PM   #2 (permalink)
Default Re: Problems in opening Drive Folders
Well am not good in this part but you can reboot your PC and try the same. Probably your PC have got a Virus attack. Better use system restore instead or wait for some techies to reply.
gigyaster is offline
Old 06-04-2009, 09:09 PM   #3 (permalink)
Call me D_J!
Disc_Junkie's Avatar
It may be a autorun.inf file which automatically gets executed when you doubleclick and hence the program which gets executed,needs something to open it.
You can do one thing, check for the autorun.inf file in the root of the drives. If you find any delete it.
If you cannot delete it, do one thing. Download Noob-Killer and do a 8-X Kill and it will clear out the malware. Or you can manually remove it by selection 'browse for file'.
Link: www.freewarefiles.com/Noob-Killer_program_42299.html
If you right click on the drive, you will see a Autoplay option. You can alternatively open the drive by rightclicking and selecting Open.
ASUS K42JA-VX032D RAWKS !!!!!!:grin:
Disc_Junkie is offline
Old 07-04-2009, 07:52 PM   #4 (permalink)
Yeah! I've already tried by rebooting my office pc and also used System Restore but to no avail!!!!
Kerry is offline
Old 07-04-2009, 09:35 PM   #5 (permalink)
Banned to Spam
Krazy Bluez's Avatar
Location: Look below...not under pants dumbo...use a GPS
System restore would do nothing at all, do what DJ said and it'll clear all malwares..
My DeviantART page now exists !!!
Krazy-Bluez.deviantart.com
Twitter: http://twitter.com/KrazyBluez
Krazy Bluez is offline
- by Krow
