Old 08-09-2004, 01:20 AM   #1 (permalink)
tango_cash's Avatar
Default is my p.c config suitable for a dvd drive
i need some info on dvd drives .my pc's config is - 333mhz celeron processor , intel 810 motherboard , 128 mb ram , 20 gb hdd, a c.d writer(52x L.G), a CREATIVE c.d rom. win 98 s.e. now what i wannna know is can i instal a dvd drive on my p.c is my configuration o.k or do i need to upgrade my p.c . also is a good graphic card neccesary for a dvd drive. also do i have to remove my creative drive to install the dvd drive or can i have all three of them(L.G WRITER,CREATIVE C.D DRIVE AND DVD DRIVE) together. one more thing can u suggest a good dvd drive which plays all formats of dvd like dvd audio etc,also will the dvd drive be region locked or region locking is only for the dvd players which are used with t.v. please help
tango_cash is offline
Old 08-09-2004, 07:37 AM   #2 (permalink)
u can install a dvd drive provided that u have an empty bay and if ur mobo supporst another drive. else u might have 2 remove ur existing drive. u should remove ur cd drive as ur dvd drive will read cds.
Nemesis is offline
Old 08-09-2004, 10:11 AM   #3 (permalink)
The Photoshop Guy
cooljeba's Avatar
Welcome to the forum m8
yes u can install a DVD rom in your system. Provided u have place in ur cabinet and have extra data cable's. Yes ur mobo must support it to ( i means 3 drives ) or u need to remove one!!!
m8 think abt a combo also b4 u buy a DVD rom as costs have gone down!! then u can remove everything . I am using SONY DVD Rom and it's cool .
..:: peace ::..
Jeba
cooljeba is offline
- by Krow
