Old 12-06-2005, 06:29 PM   #1 (permalink)
himtuna's Avatar
Default I want to buy an external hdd.
hi
I want to buy an external hdd which is portable(for my laptop)
My bugdet is Rs 10000. I checked this months Digit and liked western digital 40 GB hdd but it's website www.wdc.com has more good hdds with extra gigs.I am confused. please help me.
http://www.himtuna.com/
http://www.himanshuthakur.com/
Do good to be good !
himtuna is offline
Old 12-06-2005, 11:37 PM   #2 (permalink)
get ur self a external hddd casing and a 4200rpm lappy hdd
total cost around 5K
Happy Computing :lol:
krishnathelord is offline
Old 13-06-2005, 11:36 PM   #3 (permalink)
himtuna's Avatar
www.wdc.com
check above link then please reply me soon
Rs10000 for 80 GB 5200rpm portable hdd for my laptop (offcourse not a bulky one) ... will this be good
himtuna is offline
Old 14-06-2005, 12:56 AM   #4 (permalink)
hey the link isnt working
Old 14-06-2005, 10:20 AM   #5 (permalink)
himtuna's Avatar
CHECK THIS ONE
http://www.wdc.com/en/index.asp?Language=en
himtuna is offline
Old 14-06-2005, 10:46 AM   #6 (permalink)
gxsaurav
Posts: n/a
seagate 5 GB external
Old 14-06-2005, 08:10 PM   #7 (permalink)
himtuna's Avatar
GOsh I don't want to buy just a 5 gig hdd something like a figure of 80 gb
himtuna is offline
Old 14-06-2005, 08:31 PM   #8 (permalink)
Aren't they expensive? Why not get a regular 3.5 incher and an USB hard disk case.
-Keith
Keith Sebastian is offline
Old 15-06-2005, 12:53 AM   #9 (permalink)
yes but they arent exactly portable
Old 19-06-2005, 02:55 PM   #10 (permalink)
regular HDDs are not portable and are not supposed to be moved or carried on a regular basis. So in this case a mobile HDD will do, but is expensive.
If you only want to use the HDD at home or keep it located on u r desk then the regular HDD is good option.
IBM ThinkPad R51 2887 LQ3 [P M 715(1.5GHz), 256MB RAM, 40GB 4200rpm HDD, 15in 1024x768 LCD, Intel Extreme, 24x10x24x/8x CD-RW/DVD, Intel PRO/Wireless 2200BG , Modem(CDC), 10/100 Ethernet(LOM), UltraNav, Secure Chip, 6 cell Li-Ion battery, WinXP Home.]
super_i_man is offline
- by bhaskar
- by Deepaks
- by Anorion
