Old 04-04-2009, 09:54 AM   #1 (permalink)
Default media files changed to jpeg format
hi everyone, yesterday i have surfed the internet in my pc.then i went to the college.in the evening,when i opt to open the mp3 files and avi files,it have changed to the jpg format.is any other way to change it?
thecreativeboy is offline
Old 04-04-2009, 10:27 AM   #2 (permalink)
Call me D_J!
Disc_Junkie's Avatar
Default Re: media files changed to jpeg format
Assuming that it has not happened due to effect of some virus, you can do two things.
Rightclick one of the mp3, select Open with >> Choose Program,
Select the player with which you play your mp3s and tick "Always use the selected program to open this type of file" and click OK.
Or if they have changed the extensions as well then keep all the mp3s and avi separately in one folder.
Go to the command prompt,
1. Type d: (Assuming D as the drive of the songs)
2. Type CD songs(assuming songs is the song folder)
3. Type ren *.* *.mp3 and press enter
4. Do the same for the avi files, type *.* *.avi and press enter
ASUS K42JA-VX032D RAWKS !!!!!!:grin:
Disc_Junkie is offline
Old 04-04-2009, 11:56 AM   #3 (permalink)
thanks for guiding how to do it command prompt
Old 04-04-2009, 12:21 PM   #4 (permalink)
Banned to Spam
Krazy Bluez's Avatar
Location: Look below...not under pants dumbo...use a GPS
+1 with DJ...
My DeviantART page now exists !!!
Krazy-Bluez.deviantart.com
Twitter: http://twitter.com/KrazyBluez
Krazy Bluez is offline
- by Krow
