Old 12-06-2005, 05:38 PM   #1 (permalink)
trigger's Avatar
Default Yahoo messenger, Powertools !!!!
No Ads
Remove the ads from the bottom of chat, conferences, webcam, and change room screen when using Yahoo Messenger 5.0, 5.5, 5.6 and 6.0
Download Here [1.62 KB]
DenyBuddy
Remove your Yahoo ID from someone else's contact list.
Download Here [68.8 KB]
Yahoo Messenger Archive Reader
Yahoo messenger requires you to be logged in to read your messenger archives. This program lets you read your messenger archives without logging in. It will display your Yahoo! messenger archives as they were meant to be displayed apart from no smileys. You can then save the Yahoo messenger archive you are currently viewing as a richtext file or as a web page.
Download Here [225 KB]
Winamp Status Changer
Changes your Yahoo! Status to the current song playing in Winamp..
Download Here [15.8 KB]
Yahoo! Multi-Gold Loader
Allows multiple instances of Y!M. This allows you to sign in under multiple ID's without aliases.
Download Here [859 KB]
Smiley Utility
user posted image
It's a small utility which stays in the system tray, and when selected, offers you a list of all 60/79 Yahoo! Messenger smileys. Also stored with each image is the code. When you select a smiley, it will automatically insert the code into Yahoo! Messenger Chat, or a Yahoo! Messenger PM, if you don't use Yahoo! Messenger, or it doesn't automatically insert, their is a copy to clipboard option instead.
When you select a smiley, it looks up the code on its internal list and sends a window message to Yahoo! telling it to add the smiley code to your text. If it doesn't do this, it has copied it to the clipboard instead, then wherever you want to use the smiley, right click and select paste, and it will paste the code. The program can be run from within any folder.
Download Here [190 KB]
Are you watching closely?
trigger is offline
Old 12-06-2005, 09:01 PM   #2 (permalink)
Just Do It
I was looking for the Deny buddy stuff. Tks
Charley is offline
