| Forum |
#3 (permalink) |
please suggest something for the reverse conversion. i mean DVD to mpeg.
i have a dvd with region other than india and U.S. and hence, it's unplayble in all the dvd players, giving errors like " unknown region " any software to play that DVD without changing the region of my sony dvd rw.
Be not Thou far from me o Lord....o my strength....haste Thee to help me. |
#4 (permalink) | |
Another Brick in the Wall
U can remove the region code using firmware upgrade, see this for more info... http://www.artecusa.com/tech-support-firmware.html But anyways, i have never tried it, and ask support from members/dealers before going on... Hmm... after u unlock ur drive, u can install DVD Region Free, It also supports region-locked (RPC-2) DVD drive, and does not require firmware modifications. It has no previous limitations and it will work, even if you can not change the DVD drive's region anymore. http://www.dvdidle.com/dvd-region-free.htm
I Love Photography. I Love Aperture. I Love Mac. |
#5 (permalink) |
SABER RIDER
@pranay
Use #1 DVD Ripper to rip that DVD into any format u like.....(why mpeg....it takes lotta space)........rip it to avi using VP62 & Lame MP3 ....... for the steps on how to do it see my siggie topic..... Im telling u to use #1DVD Ripper cos it rips DVDs which have a different region too...... try it out....... also go to www.doom9.org n look for region free tools.............
Find out Which is The Best Video Codec?....And how to encode video the right way..!!----->>>>> http://www.thinkdigit.com/forum/showthread.php?t=3908 |
#6 (permalink) |
thanx for the advice maverickrohan, but the player that i have in my car can only play mpeg, vcd, svcd media.
thanx drgrudge and maverickrohan for the usefull information.
#7 (permalink) | |
http://dhc014.rpc1.org/LtnRPC/ You can do it via the web interface. No need to download. Or get your Sony/Liteon firmware from here. http://codeguys.rpc1.org/firmwares.html Get the Sony one that says LED fix for your corresponding drive. This will make you Sony drive LED flash RED while writing like the Liteon. Also with Omnipatcher (same site) you can custom modify firmware before you flash. The possibilities are endless. Getting your hardware to be region free is just half the battle won. Software like PowerDVD, WinDVD maintain a seperate count of region changes. Read this - http://forum.rpc1.org/viewtopic.php?t=239 Keith
[ THIS SPACE HAS BEEN RESERVED FOR FUTURE USE IN CASE I WANT TO BOAST ABOUT MY PC'S, HOUSE, CAR, GIRLFRIENDS OR OTHER STUFF THAT I KNOW YOU DON'T REALLY CARE ABOUT ] |
#9 (permalink) | |
BTW I could not find a region free firmware for your drive - http://forum.rpc1.org/dl_firmware.php?download_id=1972 Strange! EDIT ADD: Wow! You've got a one of a kind drive. I think it's time for you to get a new one. Or exchange it with an unsuspecting friend EDIT ADD 2: Read this thread http://club.cdfreaks.com/showthread....hlight=DDU1622 Is it same as Liteon 166s? You can try flashing from my codeguys link. Remember to make a backup with EEPROM Utility from the same site (under utilities) -Keith
#10 (permalink) | |
Just Do It
#11 (permalink) | ||
Slowly as in "stuttering"?. It could be anything from a poor quality encode to lack of enough processing power for decoding (like trying to play a HD video from here on an underpowered system. Use Gspot and post file details. -Keith
#13 (permalink) |
GSpot won't play video files. It's just there to inform you of codecs used. What does it report under video and audio? Does it say anything about missing codecs? If it does not, then most probably your file is a poor encode.
-Keith
#14 (permalink) | |
The source video file needs to confirm to the following specs - Format - MPEG2 PAL - Resolution of 720x576 (full d1) or 704x576 (broadcast d1) at a framerate of 25fps NTSC- Resolution of 720x480 (full d1) or 704x480 (broadcast d1) at a framerate of 29.97fps Remember - Lower (half) resolutions are accepted. Max Bitrate - 9.8Mbps The Audio source file should be - Frequency - 48000 Hz Format - Mpeg1 Layer2 (MP2), Dolby Digital (AC3), DTS or PCM Wav. Channels - 2 for MP2, upto 5.1 (6) for others. Max Bitrate - Total of 1536 Kbps for all channels combined How to make the VOB - Download IFOEDIT - http://ifoedit.wh.fr0zen.com/download/Ifoedit0971.zip Make a folder by name VIDEO_TS. This is your destination folder for the VOBS. Open IFOEDIT, select DVD Author>Author New DVD Select Video, Audio source and final destination folder. Hit OK. It'll take sometime to multiplex depending on size. Multiple VOBS of max size 1gb each will be created. How to play - Drag the VIDEO_TS folder into WINDVD. Offcourse there are many other ways, this is just my preferred method. How to burn - Use Make DVD-Video option in Nero. Doubleclick to open the (red) Video_ts folder on the left pane. Drag (all) contents from the VIDEO_TS on your hard disk here. Note: The Audio_ts folder remains empty. Hope that's cleared most of your doubts. Cheers, Keith
#15 (permalink) | |
Just Do It
#16 (permalink) |
Can you post a screenshot of GSpot. I have a feeling the file may be DRM'ed. Stay away from WMV and Microsofts crappy licensing policies.
Post a link to your source, if possible. -Keith
| Bookmarks |
| Display Modes | |
