Old 07-09-2004, 11:23 PM   #1 (permalink)
ashi8902's Avatar
Default I need help to build a project in VB6 with access
I need some help to making a commercial cataloging software and making customized reports related to them.
Shahab Akhtar
ARTOGRAPH MBD
09837049935
ashi8902 is offline
Old 08-09-2004, 01:16 AM   #2 (permalink)
Access is a good choice for small development projects where your volume of data to be stored in the database, is less. However, access is a desktop
database, and is not a true RDBMS, so consider using SQL Server for better
performance and support for things like concurrency and integrity.
For report generation you have two options as far as VB is concerned. Either
go in for the inbuilt Report Designer or opt for a third party report generation solution such as Crystal Reports.
If the reports you plan to produce are simple enough, then the inbuilt Report designer would be all you need. Otherwise Crystal Reports is the way to go!
sailendra is offline
Old 08-09-2004, 12:36 PM   #3 (permalink)
tuxfan's Avatar
Please give more details about your project.
tuxfan is offline
Old 12-09-2004, 01:58 PM   #4 (permalink)
i prefer using crystal reports when doing a vb project......its easy to build customized reports fast !
a wise man once said:
\"he who laughs last.........doesn\'t get the joke\".
shehan9999 is offline
- by Krow
