Re: change the spacing in TAB key
Am I missing something here? You said that in Word, etc., the Tab key gives a spacing of 4 characters. MS Word sets Tab spacing in linear measurement like inch, cm, mm, pt and pica. The length of Tab spacing can be set under Menu > Format > Tab. Normally, it's only with very basic text editors that Tab spacing is fixed in characters. Correct me if I misunderstood some of the points raised in the thread.
