Old 31-03-2009, 06:26 PM   #1 (permalink)
Default system not detecting 4 gb ram
i recently upgraded to 4gb ddr2 ram and using XP 64-bit SP2 OS....Xp only recognizes 2.9GB. also when checking whether games are compatible or not using
systemrequirementslab.com it only shows 2.9GB of RAM. wat should i do to make my system recognize 4GB? i use asus commando motherboard. plz help and thx..
vamsi23 is offline
Old 31-03-2009, 06:46 PM   #2 (permalink)
Democracy is a myth
rhitwick's Avatar
Default Re: system not detecting 4 gb ram
How many RAM sticks do u use? is it 2*2GB? Are all of them of same frequency.
Try upgrading XP to SP3.
And, do prodive ur full system config.
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is online now
Old 01-04-2009, 01:17 AM   #3 (permalink)
Banned to Spam
Krazy Bluez's Avatar
Location: Look below...not under pants dumbo...use a GPS
If it's 64 bit then it should detect all the RAM...check if you're running in Dual-Channel Mode in BIOS...
My DeviantART page now exists !!!
Krazy-Bluez.deviantart.com
Twitter: http://twitter.com/KrazyBluez
Krazy Bluez is offline
Old 03-04-2009, 04:57 AM   #4 (permalink)
its 2*2 GB ddr2 800mhz Transcend both same frequency....I use XP SP2 x64 OS...
ASUS Commando motherboard
Leadtek 8800GTS 640MB
Seagate 250 GB SATA2
Samsung SH-S223 SATA optical drive
Zebronics 500watts PSU
and how do I check whether its running in dual channel mode in bios??? previously I used 1*1GB ddr2 667mhz and it worked fine..I checked using CPUZ, it shows total size 4096MB in SPD tab, it shows correctly slot#1 2048MB and slot#3 2048MB
vamsi23 is offline
Old 03-04-2009, 12:02 PM   #5 (permalink)
Banned to Spam
Try booting with a live linux distro and check whether it is detecting the full ram or not
- by Krow
