Old 11-06-2005, 11:34 PM   #1 (permalink)
bharat_r's Avatar
Default convert form Xvid.AC3 to VCD dat.How??
1.I have a DVD rip in Xvid with AC3 dolby format(as avi).I don't have a DVD writer.So I can burn it only as a VCD.
When I burnt it(using Nero) as a VCD & put it in my VCD player,I can see only the video & there is no audio.
I tried converting the file to mpeg(using Advanced X Video Converter).
79 min file took up 1.3 GB & nero says file's to big.
How do I burn it to a VCD(dat) which is playable in my VCD player with Video as well as Audio.
2.I searched the forums for this & found that VCD 2.0 does not support dolby sound is there a next version of VCD like 3.0 which does?
bharat_r is offline
Old 12-06-2005, 12:00 AM   #2 (permalink)
QA Juggler
saROMan's Avatar
Visit Here and Here and Here ..for all kind of help regarding the query.....
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 12-06-2005, 01:23 AM   #3 (permalink)
bharat_r's Avatar
Thanks!I'm processing the video using TMPG.
I'll post back if I find some difficulites.
in the first link:
Use a burning program, such as NERO to burn your CD-R or R/W CD as a VCD (DON'T ask NERO to format the file as a VCD, since you've already accomplished this!)
how to do that????
bharat_r is offline
Old 12-06-2005, 05:16 AM   #4 (permalink)
SABER RIDER
maverickrohan's Avatar
Download AimONE Video Convertor n convert the file to VCD(PAL) n i guess u have a AC3 decoder installed......
79 minute video will definately fit on a single VCD
thats cos the standard VCD bitrate is 1150kbps n the 1.3GB u got was probably cos the MPEG u encoded was using 2350kbps MPEG
Find out Which is The Best Video Codec?....And how to encode video the right way..!!----->>>>> http://www.thinkdigit.com/forum/showthread.php?t=3908
maverickrohan is offline
Old 12-06-2005, 05:29 AM   #5 (permalink)
Fresh Stock Since 2005
Install ACE codecs Pack(from Some Digit CD..... i think last month's.......) and download Power Video Converter( this is also available in Old Digit CD, I think April 2004, but I dont remember)......... and convert it into a MPEG format........... Then burn with Nero as Usual (hope you know how to burn Video Files, don't you??... you should not directly burn it as a data but you should burn it as a video......)
hope you get it.........
http://www.khattam.info
khattam_ is offline
Old 12-06-2005, 05:35 AM   #6 (permalink)
bharat_r's Avatar
saROMan,
I followed the steps told in the first link u gave(http://forum.digital-digest.com/arch...23203-p-1.html)
In the resulting mpeg file Audio & Video do not syncronize.Video comes first then the audio
I'll try what maverickrohan & khattam_ have said.
bharat_r is offline
Old 12-06-2005, 07:52 AM   #7 (permalink)
use avi2dvd . specify output source as cd . write the image files created 2 ur cd
hope this works out , it generally does 4 most guys
the genius of the hole : no matter how hard u try 2 get 2 the top , 1 mistake n u start again
mamba is offline
Old 12-06-2005, 02:17 PM   #8 (permalink)
bharat_r's Avatar
no use tried everything but audio is ahed of video by about 30 secs.
bharat_r is offline
Old 12-06-2005, 02:51 PM   #9 (permalink)
QA Juggler
saROMan's Avatar
u are trying to convert the Avi file or the MPG file ???
saROMan is offline
Old 12-06-2005, 03:25 PM   #10 (permalink)
bharat_r's Avatar
tried both
I used TMPGEnc to convert it to mpg, also tried Dr.DivX to convert it to DivX avi...but still Audio & Video are not in phase.
I think the AC3 audio is causing the problem.
bharat_r is offline
Old 12-06-2005, 03:27 PM   #11 (permalink)
bharat_r's Avatar
does it depend on disc space.I have only 3 GB of free space in C drive(in which the tools are installed)
The E drive has 5 GB free space.
Will it make any difference?
bharat_r is offline
Old 13-06-2005, 04:09 AM   #12 (permalink)
SABER RIDER
dude...........Why dont u try AimONE Video Convertor Like I said b4.............It is very stable n supports VBR Audio too
A 30 second lag in A/V syn can only b caused by VBR Audio........
Try AimONE n then tell me the results.......!!!
Old 13-06-2005, 08:39 AM   #13 (permalink)
bharat_r's Avatar
I'm downloading it now.Will try it.Thanks!!!
bharat_r is offline
- by Krow
