Originally Posted by NucleusKore
Just remove the nylon steering wheel cover for a few days and see. It should solve your problem
ya will try this
Originally Posted by amitash
This might not be feasable but touch a metal surface connected to the ground before getting out of your car...like a water pipe or sth.
Where am i going to find a pole or a pipe in parking..... or i should be carrying it in my car but still the moment i try to ground it i will still get the shock. Only difference is I will be able to get the shock as per my choice..
Originally Posted by FilledVoid
You could cover the driver seat with a nice towel I guess and put a mat on the floor of your car . You might not need that but I'm not sure if you are using a carpet as it is. If it is then that might be causing it as well. This usually happens to me in US when you walk around on a carpeted floor with socks and then grab a metal door knob.
Well I am using a rubber foot mat ........ and yes i will keep a towel now for some time.
I have a doubt now. There could be two possibilities
1. The car and self are getting static charge but the car is unable to discharge it to the ground because of the tyres and with those shoes I am conducting that charge to grd because of which I am getting a shock.
2. The car is at the same potential as that of earth but my body is getting charged because of some reason and when i try to get out and get in contact with the metal I get a shock as the charge gets discharged.
What could be the case??? If the first case is true then i think i can hang a metal wire hanging which will contineously discharge from car to ground.
