Hmm...
please use the search function of the forum first then post...
Anyway here it is...
Ok Fat32 file system has a few limitations like
1: Maximum file size is limited to 4GB(if u are not into video editiing or some programs that require huge file sizes)
2:Absolutely no inbuilt security(can use 3rd party programs)
3: No logon security( Can use 3rd party..Steganos)
4:Tend to get fragmented easily
5:You get a Scandisk prompt every time u shutdown directly
6:Cannot get a efficient sector size.
7: Prone to Dos viruses..(HardriveKillerpro can earase ur HDD in 3 secs)
Pros of NTFS
1: Can set file folder permissions
2: Can limit other user acces to ur files
3: it doesn't get fragmented as often like fat32
Cons of NTFS
1: Not backward compatible to fat32 unless u use partition magic in dos mode
2:However its damn troublesome to recover a NTFS volume incase something bad happens
Risk more than what others think is safe.
Care more than what others think is caring.
Think more than what others think is thoughtful.
Do more than what others think is possible.
NTFS is better and more secure, but the only thing that keeps me away from it is that NTFS Drives dont work in Dos and Older Versions of Windows (9x).
Use a third party tools like Paragon NTFS mounter or Paragon Mount anything in Win98...
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
\"99 little bugs in the code, 99 bugs in the code, fix one bug, compile it again, 148 little bugs in the code. 148 little bugs in the code....\"
NTFS is better, more secure and the only option if u ever wanna set security permissions, but, forget about dual booting into any 9x based operating system if u've got your primary partition as NTFS !
~Therez a difference between knowing the path and walking the path ~
