Old 11-06-2005, 04:35 PM   #1 (permalink)
Default Floppy Media not recognised Plz help
I have a floopy which has software used in GE CT scanner. When I use this floopy to my or any computer it says its media not recognised. would you like to format it? This floppy is in good condition because it works on CT scanner. Windows XP and Red hat linux couldn't recognise it.
How can I read this floopy to my computer and how can I make exact dublicate copy of it?
Can anybody help me on this topic as soon as possible Plz.......?
angel_dinesh is offline
Old 11-06-2005, 04:45 PM   #2 (permalink)
i too faced the same problem, try running it in older OS like Win98 and then if possible mail the file to urself. WinXP has some problems in reading floppies coz the same floppes work on other operating systems. This is wat i feel and has xperienced
Shwetanshu Srivastava
shwetanshu is offline
Old 11-06-2005, 05:20 PM   #3 (permalink)
But I tried it on win98 also but it didn't work?
same error message.
Old 11-06-2005, 09:52 PM   #4 (permalink)
q3_abhi's Avatar
Try it on ur friends pc
q3_abhi is offline
Old 13-06-2005, 10:30 AM   #5 (permalink)
I tried but it gives same message. I think it some sort of file system problem. plz help anybody.
Old 13-06-2005, 11:29 AM   #6 (permalink)
l33t n00b!
Nimda's Avatar
Try using the following software:
1- Alkonost Maxformat 3.50
2- BadCopy Pro
3- Active Floppy Recovery 2.0
4- Recover Fixed/Floppy Disk v1.4 <-- Freeware!
Nimda is offline
Old 13-06-2005, 12:50 PM   #7 (permalink)
Dear Nimda
Can it be a problem of file system of floppy? Perhaps windows is not recognising the file system or it is not FAT, some other file system used in GE software floppies.
Please reply ASAP.
Old 14-06-2005, 05:09 AM   #8 (permalink)
ON my WIn 98 computer when i click on blank or filled floppy it says
DO u want to format it
But when i go in dos when starting the computer
floppy drive reads it.
ALso i can do full or quick format.
ALso in safe mode all files can be read and copied to it also
but why in normal mode it is telling do u want to format the floppy
I tried 5-6 floppies all are giving same error
Also is there any emulator for floopy drive to boot from dos if win cant start
instead of booting from cd drive
LIke i have A drive but dont have B drive
I want to create boot cd but cant do it because floopies cant be read from the drive .
For creating boot cd Easy cd creator wants floppy in floppy drive
AMIT AGARWAL
AMITAGARWAL02 is offline
Old 26-06-2005, 07:01 AM   #9 (permalink)
any update on floopy errors in windows thanks
AMIT AGARWAL
Old 26-06-2005, 09:15 AM   #10 (permalink)
vishal_bhatia87
Posts: n/a
Iam happy coz I don't have floppy drive in my computer.
Old 07-07-2005, 01:15 AM   #11 (permalink)
floppies are working in same mode
but why not in normal mode
AMIT AGARWAL
Old 07-07-2005, 05:10 AM   #12 (permalink)
q3_abhi's Avatar
You can use one excellent utility called TFormat which will format your floppy even if its track 0 is bad!!!
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
- by Krow
