Old 25-03-2009, 08:23 PM   #1 (permalink)
Default I am not able to get 1440*900 resolution.
I also installed the driver that i think it is latest from the below URL mentioned but it is not helping.
Do you have any suggestions? Thanks for your help in advance.
(http://www.viaarena.com/default.aspx...0&SubCatID=109)
My PC configuration:
Motherboard: ASUS K8V-MX (Socket 754)
CPU AMD Athlon 64 with 800mHZ
Graphics: Internal. VIA/S3G Unicrome(K8M800) Pro IGP
ajincoep is offline
Old 25-03-2009, 09:54 PM   #2 (permalink)
Intel OCer
amitash's Avatar
Default Re: I am not able to get 1440*900 resolution.
First of all, Does your monitor support the res? and did you try changing res in the windows settings or the gfx ctrl panel?
My site: collegeclassroom.org
amitash is offline
Old 25-03-2009, 10:02 PM   #3 (permalink)
j1n M@tt's Avatar
I don't think the VIA/S3G Unicrome can handle such a high resolution
j1n M@tt || "a guy who gets off bed only b'coz of technology..."
j1n M@tt is offline
Old 25-03-2009, 10:19 PM   #4 (permalink)
Call me D_J!
Disc_Junkie's Avatar
Please give the more explaiable datails of your monitor and check Display Properties if it has support for such resolution.
ASUS K42JA-VX032D RAWKS !!!!!!:grin:
Disc_Junkie is offline
Old 25-03-2009, 10:29 PM   #5 (permalink)
UBERGEEK
PCWORM's Avatar
Must b a driver problem!
PCWORM is online now
Old 25-03-2009, 10:46 PM   #6 (permalink)
Tech.Masti's Avatar
old graphics may not be supported by this resolution
Tech.Masti is offline
Old 26-03-2009, 05:41 PM   #7 (permalink)
Cool Buddy's Avatar
Well, no need of any details, coz I know someone who had the same chipset and did the same mistake of buying 19" widescreen LCD. you motherboard won't support this resolution. Run it on 1280x1024 till you are able to buy a new mobo
Nokia 5230 :(
Canon IXUS 115 HS :)
Cool Buddy is offline
Old 28-03-2009, 08:46 AM   #8 (permalink)
Tux Fan
shaunak's Avatar
Read: http://www.thinkdigit.com/forum/arch...p/t-66889.html
You will need a dedicated graphics solution.
Cheers
Shaunak
Feel free to PM/email me.
shaunak is offline
Old 28-03-2009, 11:01 AM   #9 (permalink)
Cool Buddy's Avatar
saw that! that thread was started by me. I had asked the question for my friend. So i wrote "I bought". Actually it wasn't me who had bought it, I'm still stuck with this boring 17" CRT.
Nokia 5230 :(
Old 28-03-2009, 12:36 PM   #10 (permalink)
Banned to Spam
Krazy Bluez's Avatar
Location: Look below...not under pants dumbo...use a GPS
Have you installed the drivers ?
My DeviantART page now exists !!!
Krazy-Bluez.deviantart.com
Twitter: http://twitter.com/KrazyBluez
Krazy Bluez is offline
Old 30-03-2009, 11:45 PM   #11 (permalink)
Sorry not to mention that i have a 19" monitor.
and i posted this questions in some of the other forums and I got the same reply that Cool Buddy says - My Chipset do not support that resolution. I need a Graphix card to get that resolution.
Do you recommend any card for my PC configuration? PSU is 400W. Other details i hv mentioned in the subject of the thread.
Answers to other queries->
Yes, i installed the latest drivers.
I also checked that BIOS update wont help.
ajincoep is offline
Old 01-04-2009, 10:46 AM   #12 (permalink)
Cool Buddy's Avatar
your mobo supports SATA HDD, so if you are lucky, you would have bought a SATA HDD. if that be the case just buy a new motherboard. A mobo from asus would cost you around 2000 & will support the resolution. you will need to buy 1GB DDR2 RAM, i suggest you buy transcend 667Mhz, costs around Rs. 550-600. this is the same as a graphics card will cost. however ir gives you the option of upgrading later on as these mobos support AMD phenom processors & PCIe graphics cards.
Nokia 5230 :(
- by Krow
