Its a hell of a task to remove it manually. First of all try using MS Antispyware and Ad-Aware if you haven't used it.
Otherwise this is the manual process:
1.Stop Running Processes:
Kill these running processes with Task Manager:
30.exe
34yf28fg.exe
c:\temp\salm.exe
gm.exe
istsvc.exe
iunkjjsc.exe
profilepath+\local settings\temp\msbb.exe
profilepath+\local settings\temporary internet files\content.ie5\8pcv4roj\internetfeatures[1].exe
profilepath+\local settings\temporary internet files\content.ie5\g1ppl2yl\msbb[1].exe
programfilesdir+\180solutions\fleok\msbb.exe
programfilesdir+\180solutions\msbb.exe
programfilesdir+\180solutions\sais.exe
saie1101.exe
salm.delete.exe
shopinst.exe
systemroot+\adg.exe
systemroot+\avghalsb.exe
systemroot+\cjqxe.exe
systemroot+\knuzql.exe
systemroot+\qhutst.exe
systemroot+\temporary internet files\content.ie5\klyrklmh\msbb[1].exe
videoinst.exe
2. Remove Autorun Reference:
Go To the key HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\Curr entVersion\Run
If you find the value HKEY_LOCAL_MACHINE\software\microsoft\windows\curr entversion\run\adg, delete it and reboot the machine immediately.
If you find the value HKEY_LOCAL_MACHINE\software\microsoft\windows\curr entversion\run\cjqxe, delete it and reboot the machine immediately.
If you find the value HKEY_LOCAL_MACHINE\software\microsoft\windows\curr entversion\run\salm, delete it and reboot the machine immediately.
If you find the value HKEY_LOCAL_MACHINE\software\microsoft\windows\curr entversion\run\shytersd, delete it and reboot the machine immediately.
3.Unregister DLLs:
Unregister these DLLs with Regsvr32, then reboot:
atpartners.dll
c:\temp\salmhook.dll
programfilesdir+\180solutions\msbbhook.dll
programfilesdir+\180solutions\ncmyb.dll
programfilesdir+\180solutions\saishook.dll
sfbho.dll
systemroot+\downloaded program files\conflict.1\ncaseinstaller.dll
systemroot+\downloaded program files\conflict.1\ncaselib.dll
systemroot+\downloaded program files\ncaselib.dll
4.Clean Registry:
Remove these registry items (if present) with RegEdit:
HKEY_CLASSES_ROOT\interface\{8dd50c56-8a07-40b9-98c4-3f169e3ae28e}
HKEY_CURRENT_USER\software\180solutions
HKEY_CURRENT_USER\software\salm
HKEY_LOCAL_MACHINE\software\180solutions
HKEY_LOCAL_MACHINE\software\iefeatures
HKEY_LOCAL_MACHINE\software\microsoft\windows\curr entversion\app management\arpcache\ncase
HKEY_LOCAL_MACHINE\software\microsoft\windows\curr entversion\moduleusage\c:/windows/downloaded program files/conflict.1/ncaseinstaller.dll
HKEY_LOCAL_MACHINE\software\microsoft\windows\curr entversion\moduleusage\c:/windows/downloaded program files/conflict.1/ncaselib.dll
HKEY_LOCAL_MACHINE\software\microsoft\windows\curr entversion\moduleusage\c:/windows/downloaded program files/ncaselib.dll
HKEY_LOCAL_MACHINE\software\microsoft\windows\curr entversion\shareddlls\systemroot+\downloaded program files\conflict.1\ncaseinstaller.dll
HKEY_LOCAL_MACHINE\software\microsoft\windows\curr entversion\shareddlls\systemroot+\downloaded program files\conflict.1\ncaselib.dll
HKEY_LOCAL_MACHINE\software\microsoft\windows\curr entversion\shareddlls\systemroot+\downloaded program files\ncaselib.dll
HKEY_LOCAL_MACHINE\software\microsoft\windows\curr entversion\uninstall\msbb
HKEY_LOCAL_MACHINE\software\microsoft\windows\curr entversion\uninstall\msbb\displayicon
HKEY_LOCAL_MACHINE\software\microsoft\windows\curr entversion\uninstall\msbb\displayname
HKEY_LOCAL_MACHINE\software\microsoft\windows\curr entversion\uninstall\msbb\uninstallstring
HKEY_LOCAL_MACHINE\software\microsoft\windows\curr entversion\uninstall\ncase
HKEY_LOCAL_MACHINE\software\microsoft\windows\curr entversion\uninstall\salm
HKEY_LOCAL_MACHINE\software\msbb\boom
HKEY_LOCAL_MACHINE\software\msbb\boom_ver
HKEY_LOCAL_MACHINE\software\msbb\did
HKEY_LOCAL_MACHINE\software\msbb\duid
HKEY_LOCAL_MACHINE\software\msbb\gma
HKEY_LOCAL_MACHINE\software\msbb\gpi
HKEY_LOCAL_MACHINE\software\msbb\gvi
HKEY_LOCAL_MACHINE\software\msbb\mt1
HKEY_LOCAL_MACHINE\software\msbb\mt2
HKEY_LOCAL_MACHINE\software\msbb\mt3
HKEY_LOCAL_MACHINE\software\msbb\partner_id
HKEY_LOCAL_MACHINE\software\msbb\product_id
HKEY_LOCAL_MACHINE\software\salm
5.Remove Files:
Remove these files (if present) with Windows Explorer:
180ax.log
180ax_gdf.dat
180ax_kyf.dat
180axau.dat
180solutions.txt
30.exe
34yf28fg.exe
atpartners.dll
c:\temp\salm.exe
c:\temp\salm.log
c:\temp\salm_kyf.dat
deleteatreboot.bat
dumprep.exe-1b46f901.pf
dwwin.exe-30875adc.pf
gm.exe
istsvc.exe
iunkjjsc.exe
pestpatrol.exe-0bbbd3d1.pf
profilepath+\recent\salm.log.lnk
saie.log
saie1101.exe
sais.log
sais_gdf.dat
sais_kyf.dat
saisau.dat
salm.delete.exe
salm.exe-1f186734.pf
salm.exe-27b5f52a.pf
salm.lnk
salmau.dat
sfbho.dll
shopinst.exe
systemroot+\adg.exe
videoinst.exe
working.lnk
systemroot refers to C:\Windows\
programfilesdir refers to C:\Program Files\
profilepath refers to C:\WINDOWS\system32\config\systemprofile
Phew! Isnt that huge?
DO a scan using
HijackThis and post the log file here.
