| Forum |
#1 (permalink) |
No pain....No gain
--------------------------------------------------- Faith is the boast of a man who is too lazy to investigate. --------------------------------------------------- |
#2 (permalink) |
Core i7 (nehalem) Owner
Yes dude, there's a particular way of using ur UPS to increase its long life and to protect ur PC from power surges from any abstract power voltage.
Steps to follow and to keep in mind:- 1.)When u switch OFF ur UPS,please do not again switch it ON all of a sudden, wait for 5-6 seconds before doin so(and vice versa) coz this will prevent any strain on the UPS battery and increase its long life. 2.)Once in a month or say 15 days,turn OFF ur UPS for half an hour and then turn it ON to recharge the batery.By doin so,the battery will always be in a good condition and will be in a state of CHARGE as well as DISCHARGE and the power failures will be prevented most efficiently by ur UPS. 3.)DO not overload the UPS other than its recommended rating i.e avoid connecting ur Printer/scanners and telephone cables to ur UPS otherthan the PC wire if the UPS rating doesnt supports it,Coz the bottom line is to prevent ur PC and its components from failure(wich is a high priority) otherthan ur Printers/scanners etc. 4.)Always check for loose connections and keep the UPS well ventilated (by keeping normal surrounding air to flow into the device).Do not stack books,modem or any other devices or components on top of ur UPS device. these r sum points wich u can follow to make ur UPS in an ever running condition.... (if i hv mentioned sumthing wrong or inaccurate in this reply,PLZ guys feel free to correct me by "quoting" my mistakes in ur replies) ![]() thanx, cheers n peace.... |
#3 (permalink) |
l33t n00b!
Also, if the voltage fluctuates violently for more than 2-3 times, then switch of the UPS immediately and turn it back on only when the fluctuations have stopped.
My UPS got blown twice due to the above problem. |
#4 (permalink) |
No pain....No gain
thank you ashu888ashu888 for ur detailed reply. But one more question, do I keep the ups on if I am not using the pc or switch it off but keep the switch at the main socket on. Also when my room's ac's compressor turn on or off the ups goes into backup mode, simultaneously, and then work normally during the rest period. Any idea why it happens.
#5 (permalink) | ||
john_the_ultimate wrote:
SO make sure that u hv not connected ur UPS and ur AC in the same socket,if u hv connected then plz connect ur UPS in a free socket and ur AC into a new 15 Ampere power supply socket and this shud solve ur problem and do post ur results here so that i/we can help u more efficiently : )cheers n peace...
#6 (permalink) |
Let the music play.....
Hmm wonder if you guys have the same setting, I have a big 2.2 KVA ups from APC (it costed me 65k). The speciality of this ups is that u don't need to keep it on to charge it. Just plug the cord in the mains and it charges the battery itself. This is a good feature coz if ur battery is descharged and u leave the ups on to charge and the power goes off the battery again discharges
Long back, a person who sacrificed his sleep, forgot his family, forgot his food, fogot laughter were called "Saints" But now they are called.."IT professionals" |
#7 (permalink) |
No pain....No gain
ashu888ashu888 I have the ups as well as ac piont seperated and they do not connect to the same socket.
#8 (permalink) |
Well i am a bit LOST for WORDS bro !
cheers n peace... |
#9 (permalink) |
Many good branded UPS dont need to be switched on for battery charging. All you need is to keep the mains to the UPS on.
Also if you dont have any power cut for a whole month then its better that u run the system in UPS's battery mode to drain the battery (not fully just 75%) and recharge it. This will recycle the battery and keep it in good condition.
Kannan. Binary Bits http://www.binarybits.net |
| Bookmarks |
| Display Modes | |
