Old 11-06-2005, 02:10 AM   #1 (permalink)
Default Messenger Not Working.
Hi, I use net on Airtel Gprs but the problem is that I can't download anything or nor could I chat on messenger, They sinply do not connect to the server.
Also while downloading mp3 files a strange thing happens.
While in middle of downloading it stops abruptly and says whole file downloaded. Then when. I open the files it says thet they are corrupted.
What could be the possible reason.
freezer is offline
Old 11-06-2005, 04:02 AM   #2 (permalink)
expertno.1's Avatar
ur connection settings should be correct on comuter as well as the mobile
have goty any internet kit from the vendor ?
u have to dial *99# no.
using an internet kit driver instaled the software
ask the vendor for the software of your mobile
or write the mobile model no.
expertno.1 is offline
Old 11-06-2005, 09:14 AM   #3 (permalink)
l33t n00b!
Nimda's Avatar
Default Re: Messenger Not Working.
If you are using a P2P application like Limewire, then try using another client, like Shareaza or Ares etc. In case you are downloading the file using a d/l manager like Flashget, then also try an alternate d/l manager.
Nimda is offline
- by Krow
