Old 18-03-2009, 11:12 PM   #1 (permalink)
Unhappy fotoku.exe
can anyone tell me how to remove virus from my 4GB pen drive. It shows 46.7MB used space when i c the properties n if i try to format it gives error, i tried even in dos n when i used attrib -r -a -s -h*.* it again gave me error n showed a file named fotoku.exe which was not getting deleted. I also tried in linux(fedora 10) n when i deleted that file it appeared again, i tried on different PC also it is just annoying
sujit_g86 is offline
Old 18-03-2009, 11:19 PM   #2 (permalink)
!! RecuZant By Birth !!
naveen_reloaded's Avatar
Default Re: fotoku.exe
try to see whether it running ....
and try to format in safe mode..
and try to end all unnecessary process...
run a scan on the file... if nothing works..
Know My Thoughts..
Visit my Blog @ www.Urssiva.com
Visit My Tech Blog @ www.CloudTechnica.com
naveen_reloaded is offline
Old 19-03-2009, 01:49 AM   #3 (permalink)
Wise Old Mouse
mrintech's Avatar
Go for a full scan with the following softwares:
* http://www.superantispyware.com/download.html
* http://www.emsisoft.com/en/software/free/
Also make sure that they are updated to latest definition files and go for Full System Scan.
Else
You can always try Online Scanning. Here's the list of best Online Scanners: http://mrintech.com/5-best-online-vi...rs-you-can-use
- MrinTech :)
mrintech is offline
Old 19-03-2009, 02:17 AM   #4 (permalink)
Tech.Masti's Avatar
run a live linux cd, and format it from linux, then test it, if it also there then your pc is also infected with this
Tech.Masti is offline
- by Krow
