Old 10-06-2005, 12:09 PM   #1 (permalink)
Default How to Download while Extensions are blocked ?
Hi ! I work in a MNC now i love downloading themes for my Desktop like the ones of Talisman, Aston etc but my Company Admin has blocked .zip extension i want to download this stuff.. Tell me how ca i do that ?
Life is a game.....Play it to win.
visvo is offline
Old 10-06-2005, 02:30 PM   #2 (permalink)
GameAddict's Avatar
Default Check out Your-freedom
Hi,
You may try Your-freedom.net. The speed is limited to 64k, but I guess that must be enough in your case.BTW, it is available in executable.Just go to the site,install it and configure your browser/downloaders to use proxy:localhost and port:1080 or 8080, and you are done!
Bye!
GA
GameAddict is offline
Old 13-06-2005, 05:06 PM   #3 (permalink)
thanks buddy.. i am trying and will update you soon, if i got any problem...
visvo is offline
Old 17-06-2005, 11:32 AM   #4 (permalink)
I am also using net through a firewall, many file extentions are blocked, hope this will work out let me try. Any more suggestion to beat the firewall!
IBM ThinkPad R51 2887 LQ3 [P M 715(1.5GHz), 256MB RAM, 40GB 4200rpm HDD, 15in 1024x768 LCD, Intel Extreme, 24x10x24x/8x CD-RW/DVD, Intel PRO/Wireless 2200BG , Modem(CDC), 10/100 Ethernet(LOM), UltraNav, Secure Chip, 6 cell Li-Ion battery, WinXP Home.]
super_i_man is offline
Old 17-06-2005, 11:38 AM   #5 (permalink)
Your-freedom is the best way at the mo. It supports http/ftp/socks protocols. I use it all the time. Others to try are http-tunnel, HttPortSN.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 18-06-2005, 12:57 PM   #6 (permalink)
thanks for the url of your freedom BUT here this site is also blocked by the firewall!!! Let me try the others
Old 18-06-2005, 01:00 PM   #7 (permalink)
all are blocked
- by Krow
