Old 13-03-2009, 02:37 AM   #1 (permalink)
clmlbx's Avatar
Default Ram on M.b very urgent
can ram of 800 Mhz run on motherboard that supports 667 mhz at max . is it possible in any way. Board d946gzis. Well I am running it .
Kingston 2 gb ram 800 mhz on d946gzis intel org. board.
pls explain this some one..
well can this work any how .....like 1 channel or half of it.
Well how can I know exact frequency of ram it's working on and what ram has
Athlon II X4 635 @ 2.9Ghz   Gigabyte GA-MA785GMT-US2H   Kingston 2x2 Gb 1333Mhz DDR3   WDC 500Gb Green   Palit GTS 250 512mb   Tagan 500W   Samsung B2030   Lg DVD Writer
clmlbx is offline
Old 13-03-2009, 03:37 AM   #2 (permalink)
Default Re: Ram on M.b very urgent
The first screenshot shows that your RAM stick is working alone in single-channel mode. This has nothing to do with the RAM being DDR or DDR2. Double Data Rate (DDR) and dual-channel mean different things. If you put in another stick of the same type, then they can work together as a pair in dual-channel mode (if your motherboard supports dual-channel operation). This will give a slight boost in speed.
All DDR (1,2 & 3) RAMs process data at twice the clock frequency. DDR2/800 operates at an actual clock frequency of 400 MHz. So the info on the second screenshot is also correct. But since your motherboard provides only up to 333 MHz, your memory is working at DDR2/667 speed. IOW, the RAM is being underclocked. No harm in that. The difference is that it is not working at its full potential.
The first screenshot shows the actual operating frequency and timings of the RAM while it is being used in your computer. The second screenshot shows the specifications of your RAM.
PC2-6400 is another name for DDR2/800. In the same way, PC3200 is another name for DDR400 (the older DDR1). The basic clock for DDR400 is 200 MHz, but since it is a Double-Data Rate memory, it processes data twice in one clock cycle, so it is effectively operating at 400 MHz.
pimpom is offline
Old 13-03-2009, 03:12 PM   #3 (permalink)
clmlbx's Avatar
so in short I don't have to worry about this
ram is atleast working on 667 MHZ .. My M.B maximum support
So no problem for me now or in future.
Posted again:
right ?
clmlbx is offline
Old 13-03-2009, 03:21 PM   #4 (permalink)
yes everything is correct
Faun is offline
Old 13-03-2009, 04:50 PM   #5 (permalink)
clmlbx's Avatar
thanx Guys knew this but was very confused and wanted second opinion
thanx a lott guys
clmlbx is offline
- by Krow
