Old 09-06-2005, 10:25 AM   #1 (permalink)
Default strange problem
One of My friends PC
Intel Pentium IV 3.0 GHz
Intel 865GBF Motherboard
256 MB Ram
80 GB HDD
Windows 98SE and Windows XP Pro
shows follwing message within 5 minutes of starting any game
the same thing happens when he starts visualization in WinAmp
Your Processor has exceeded its recommended maximum temprature.
Your System has exceeded its recommended maximum temprature.
System Zone 2 temp goes to 51 from 44-45
but when he uses the PC for 3-4 hrs for word processing or for watching movies PC run perfectly without any problems & errors....System Zone 2 temp also remains near 45
Plz Help.
vishal is offline
Old 09-06-2005, 10:28 AM   #2 (permalink)
QA Juggler
saROMan's Avatar
well bud its overheating problem.....plz chk if the CPU fan is working...there is proper ventilation in the cabinate....and if possible invest in bigger Heatsink/fan .....also chk that the fan is properly fitted on the proccy
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 09-06-2005, 10:35 AM   #3 (permalink)
vandit's Avatar
Location: If I had a webcam u could have seen me, before your eyes.
Default I agree...... to some extent.....
Yup its a heating problem but as it works fine for 3-4 hrs while doing word pro. , his cpu fan goota be workin. As the problem comes while doing graphics pro. , se that your graphics card fan is workin or not ( if you dont use on board graphics card)....
Searching for dell studio 15 ??
dell studio 15 review @ my blog
vandit007.blogspot.com
And remember the stylus that comes along with the touchscreens isnt meant for cleaning your ears !!
vandit is offline
Old 09-06-2005, 10:37 AM   #4 (permalink)
expertno.1's Avatar
yeah its heating problem
aply some thermal paste also and cthe connection of the fan and see f ts working or not
expertno.1 is offline
Old 09-06-2005, 11:54 AM   #5 (permalink)
He is Using Onboard Graphics
applied thermal paste yesterday but the problem is still there
vishal is offline
Old 09-06-2005, 12:02 PM   #6 (permalink)
hey i am also facing the same probs.
where am I? who am I?
kiddo_m18 is offline
Old 09-06-2005, 12:14 PM   #7 (permalink)
club_pranay's Avatar
frnz, as told, this is only and only due to heating problem.
1.check all your fans, give your cabinet air to breathe.
2.check your CPU's heat sink... is it properly fit in? also apply a GOOD QUALITY thermal paste/compound.
3. clean your cabinet with a blower to get rid of dirl(that is a total killer for electronics)
Be not Thou far from me o Lord....o my strength....haste Thee to help me.
club_pranay is offline
Old 09-06-2005, 12:24 PM   #8 (permalink)
anomit's Avatar
More than a big fan/heatsink, its necessary to go for a big tower type cabinet. This would ensure better air flow even with small 80mm fans. Whats the point in using big fans if air cant flow inside?
Don\'t SYN me, I'll SYN you. :p
anomit is offline
Old 09-06-2005, 06:56 PM   #9 (permalink)
get one of dose table fans.........
evrytime u feel lik doin sumtin processor intensive.....
open ur cabinet an stuff da fan in its face
Be AfrAiD oF DaTA LosS........
bE vErY aFrAid!!!!!!!
irradiated_chicken is offline
Old 10-06-2005, 10:55 AM   #10 (permalink)
l33t n00b!
Nimda's Avatar
A low-quality SMPS can also cause problems like these. Make sure you have a good quality SMPS, the wiring inside the cabinet is not chaotic and all fans are in proper working condition.
To calculate how much power the PC requires, visit:
http://www.jscustompcs.com/power_supply/
Also, make sure that the SMPS has at least 24A on the 12V rail.
Nimda is offline
Old 10-06-2005, 12:15 PM   #11 (permalink)
vishal_bhatia87
Posts: n/a
◙Check all the fans for their working.
◙Check your CPU's heat sink
◙Apply a good quality thermal paste.
◙Clean your cabinet with a blower to get rid of dust.
◙Neatly tie up all the wires with rubber bands.
◙Remove the left side cover of your PC's cabinet.
◙Restore defaults if you overclocked your processor.
◙Use airconditioner (if have one) at the noon time.
