Old 09-06-2005, 06:40 AM   #1 (permalink)
Curious Guest's Avatar
Default VideoInspector 1.5.0.83
VideoInspector is a tools designed to provide you with as much information as possible about
your video files. With VideoToolbox you'll know why your video files has no sound or refuses to
play correctly. VideoInspector will help you installing the required CoDecs (coder/decoder
software) for an optimal performance. VideoToolbox can also inspect your system to find which
codecs are available, and it can also process multiple video files and export its result in HTML
or plain text files.
Download
ftp://ftp2.kcsoftwares.com/kcsoftwa/...oinspector.zip
_____________________________________
THE HELL IS FULL SO I AM BACK WITH DIGIT.
Curious Guest is offline
Old 11-06-2005, 03:21 AM   #2 (permalink)
SABER RIDER
maverickrohan's Avatar
most of the ppl use GSpot.................i think both of em do the same thing..!!!
nywaz thanx 4 the info dude...
Find out Which is The Best Video Codec?....And how to encode video the right way..!!----->>>>> http://www.thinkdigit.com/forum/showthread.php?t=3908
maverickrohan is offline
