Old 07-09-2004, 04:10 PM   #1 (permalink)
Maverick340's Avatar
Default What is Recource Hacker
What is Resouce Hacker??
Maverick340 is offline
Old 07-09-2004, 04:43 PM   #2 (permalink)
Default this is it
What is Resource Hacker
Resource HackerTM is a freeware utility to view, modify, rename, add, delete and extract resources in 32bit Windows executables and resource files (*.res). It incorporates an internal resource script compiler and decompiler and works on Win95, Win98, WinME, WinNT, Win2000 and WinXP operating systems.
Viewing Resources: Cursor, Icon, Bitmap, GIF, AVI, and JPG resource images can be viewed. WAV and MIDI audio resources can be played. Menus, Dialogs, MessageTables, StringTables, Accelerators, Delphi Forms, and VersionInfo resources can be viewed as decompiled resource scripts. Menus and Dialogs can also be viewed as they would appear in a running application.
Saving Resources: Resources can be saved as image files (*.ico, *.bmp etc), as script files (*.rc), as binary resource files (*.res), or as untyped binary files (*.bin).
Modifying Resources: Resources can be modified by replacing the resource with a resource located in another file (*.ico, *.bmp, *.res etc) or by using the internal resource script compiler (for menus, dialogs etc). Dialog controls can also be visually moved and/or resized by clicking and dragging the respective dialog controls prior to recompiling with the internal compiler.
Adding Resources: Resources can be added to an application by copying them from external resource files (*.res).
Deleting Resources: Most compilers add resources into applications which are never used by the application. Removing unused resources can reduce an application's size.
Home Page
Download
__...:::---*Keyboard Cowboy*---:::...__
whistler is offline
Old 07-09-2004, 04:50 PM   #3 (permalink)
Default Screen Shots
SCREEN SHOTS:-
whistler is offline
Old 07-09-2004, 04:50 PM   #4 (permalink)
very well done whistler
@amanwannalearn ... DO NOT MAKE REPEAT POSTS
u already have the same one on the same page
just wait for ppl to reply
No Mercy, No Limits.
theraven is offline
Old 07-09-2004, 04:55 PM   #5 (permalink)
Default thnx
felt nice to help...thats ok m8...
@amanwannalearn: anything else u wanna learn?
whistler is offline
